Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas - For discussion of all amateur band designed antennas and related accoutrements. This includes base, handheld, mobile and repeater usage. For commercial antennas on the amateur bands please use Commercial Radio Antennas below.
Old 07-12-2017, 11:48 AM
Default NMO lip mount for Equinox
Has anyone used an NMO lip mount on the tailgate of a 2017 Equinox? If so, which one will fit? The gap is pretty tight!
Thanks,
Fred WA0GMH
Old 07-13-2017, 11:40 PM
n4yek's Avatar
Here is a link of someone using a lip mount on an older model, might send him a message and talk with him:
https://forums.radioreference.com/pi...ml#post2789985
Danny
A blood donor saved my life (Matthew 26:28)
If 'con' is opposite of 'pro', is Congress the opposite of progress?
Old 07-14-2017, 9:59 AM
N8IAA's Avatar
Diamond K412SNMO. Used it on my 2011 Equinox. Will be using it on my 2017 Traverse. It uses RG316U coax. No problems fitting it through tight spaces.
Larry
Old 07-14-2017, 1:36 PM
I don't have an Equinox but the wife has a Ford Edge. It too has a fairly tight space for a lip mount on the rear hatch. However, I used the HD-5 variant by Comet and it fit fine.
Old 07-14-2017, 7:45 PM
Thanks. I check out the Diamond and Comet mounts.
Fred WA0GMH
