Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas - For discussion of all amateur band designed antennas and related accoutrements. This includes base, handheld, mobile and repeater usage. For commercial antennas on the amateur bands please use Commercial Radio Antennas below.
Old 08-07-2017, 7:14 PM
Default 30 meter antenna solution
Hi I need a 30 meter antenna that is cheap and does not require guys. I also cannot have a wire dipole. My thought now is to use 2 30 meter mobile antennas and make a vertical dipole. I'm thing about using this mobile antenna:
ProComm PCF30 - 30-Meter HF Fiberglass Ham Stick Antenna Black 500-Watt
Old 08-07-2017, 7:56 PM
Have you considered a delta loop? It is really cheap to build and can be fed with coaxial cable via a short matching section of 75 ohm cable. You can also hang it in a tree as needed. I have worked the world with this antenna.
Amateur Radio Extra Class
HackRF One, Icom IC-706MKIIG, Kenwood TS-590SG, Realistic PRO-2006, (3) RTL-SDR (RTL2832U), SDRPlay RSP, Uniden BCD536HP
Old 08-07-2017, 7:58 PM
A Delta loop is good except that I don't have the space for it or a good place to put it.
Old 08-07-2017, 8:00 PM
prcguy's Avatar
A pair of hamstick type antennas in a dipole configuration on 20m and up works ok but below 20m the efficiency is dreadful. I've tried them on 40m and they suck. A much better approach might be an end fed half wavelength of wire held up with a fiberglass mast and a 64:1 matching transformer at the bottom. That will work the same as a full size 30m vertical dipole but easier to deal with being fed at the end near the ground.
prcguy
Old 08-07-2017, 8:30 PM
Wiki Admin Emeritus
If you need to be stealthy, I think a mag loop is the best way to go. You can find plans on the net; but just to whet your appetite, here are 2 commercial manufacturers
Magnetic Loop Antennas
CHAMELEON ANTENNA | CHAMELEON ANTENNA ™
Mike.
co-author, HF Digital Decoding
Old 08-07-2017, 8:42 PM
Wiki Admin Emeritus
MFJ has several, and here's one from RR Member (still?) W4OP...
Small HF Loop Antenna | PAR Electronics
