Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Antennas
Amateur Radio Antennas - For discussion of all amateur band designed antennas and related accoutrements. This includes base, handheld, mobile and repeater usage. For commercial antennas on the amateur bands please use Commercial Radio Antennas below.
Old 06-12-2018, 11:59 AM
Default Hustler G6144B
I ordered my first 2-meter antenna this morning. I've read good reports about the Hustler G6 and wanted something above average for my first.
I also ordered an SWR meter and 75' of LMR400 cable and a short jumper cable.
The antenna will be about 30' up to the base and about 40' at the top of the radiator.
I've already hit (and miss) a repeater about 50 miles from here on 5 watts using my TH-D74A, so I expect to be hearing and talking to a lot more operators.
KD9KSO
Commercial SEL/Instrument
Old 06-12-2018, 2:31 PM
chief21's Avatar
Let us know what you think of the G6-144. It is a model that is not often reviewed.
- John AC4JK
Old 06-12-2018, 2:34 PM
I wonder why that is? It seems to be of good quality, not too pricey, and is supposed to be a good performer.
KD9KSO
Old 06-14-2018, 6:22 AM
Decent antenna but it may totally overload the front end of your HT.
I did something similar back in the 80's when I put up a homebrew J-pole at about 50 feet, and fed that to my Yaesu FT-209 handheld. A totally pegged-out S-meter at all times was the result.
That led to building a "paint-can-cavity" for 2m to deal with it.
Just a heads-up that the antenna install sounds good, but you may need a better radio / front-end to deal with that depending on your local rf environment.
Old 06-15-2018, 3:17 PM
I think the Kenwood D-74 front-end is handling the signal well. I have no problems with signal overload using this antenna.
I finally got it installed this morning before the major heat set in. I'm hitting repeaters 60 miles away and simplex communication 30 miles up the road. So far.
SWR check netted 1.2 at resonance with no adjustment needed after final assembly.
KD9KSO
Old 06-16-2018, 1:09 PM
K5MPH's Avatar
Back in early 90's we used this same antenna for our local repeater here in Brownsville,Texas it was installed on top of a water tower we got very good performance from it.....
http://www.qrz.com/db/kg5euu
Brownsville Digital Group A.R.C.
WORKING THE WORLD WITH 5 WATTS AND A RUBBER DUCK.
Old 06-16-2018, 1:12 PM
I'm very happy with the performance. Very good price/performance ratio. I don't think you can do better for a single band antenna.
KD9KSO
