Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Data Transmissions
Amateur Radio Data Transmissions - For discussion of all modes used to send data such as APRS and packet.
Old 04-11-2017, 10:55 PM
Default What are the "church bells" sound on 7.0874mhz?
I heard this at 10:51EST in the suburbs of washington DC using DSB with a 68' longwire antenna. Are they a numbers station? They sound like church bells but with no decay, just jumping up and down in tone.
Can you decode on fldigi?
Old 04-11-2017, 10:57 PM
better pic
Old 04-11-2017, 11:01 PM
zoomed in
Old 04-12-2017, 1:51 AM
majoco's Avatar
Piccolo? Domino?
Here's my "go-to" for unidentified noises!
https://www.nonstopsystems.com/radio...ml#top-of-page
Old 04-12-2017, 3:11 AM
All I see is JT65 and JT9. Set your computer clock within 2 seconds of a standard time and you should be able to decode it correctly with WSJTx
WSJT Home Page
Old 04-12-2017, 7:17 AM
Wiki Admin Emeritus
As this is clearly in the ham bands, it's been moved accordingly
We have several other sites with audio samples and waterfalls of various modes; see the Software section (which has a sub section for this) of...
Digital Amateur Radio - The RadioReference Wiki
and in our HF Appendix, there's a Sonograms section...
HF Appendix - The RadioReference Wiki
Old 04-12-2017, 7:46 AM
Have you got a recorded WAV or MP3 sample?
Old 04-12-2017, 8:17 AM
wa8pyr's Avatar
Technischer Guru
WSJT Home Page
I agree. JTxx looks and sounds as the OP described.
Pretty cool mode. Really fun for weak-signal work (I think it was originally designed for moon bounce).
Tom Swisher, WA8PYR
Lead Database Administrator
PSR500/Pro197/Pro2035+OS535/BCD436HP/TRX-1
Old 04-12-2017, 8:37 AM
Wiki Admin Emeritus
Yup, and it should be noted that JT65 has 3 variations, from what I've read - JT65A, B and C. If it is JT65, MultiPSK will handle it along with WSJT - if it's JT9, MultiPSK won't cut it, but WSJT will...
Old 04-12-2017, 11:36 AM
kb5zcs's Avatar
If its jt65 what submode is it any one know......
Sent from my LG-H345 using Tapatalk
http://www.qrz.com/db/kg5euu
Brownsville Digital Group A.R.C.
WORKING THE WORLD WITH 5 WATTS AND A RUBBER DUCK.
Old 04-12-2017, 11:48 AM
Wiki Admin Emeritus
There are some waveforms and descriptions of JT65 and JT9 here...
JT65 - Signal Identification Wiki
JT9 - Signal Identification Wiki
Old 04-13-2017, 1:21 AM
majoco's Avatar
I'll have to download WSJT, some really big signals here at 0520z/1720local on the gray line, 7076kHz. Other good DX too from all over Europe.
Old 04-13-2017, 8:41 PM
Is there an easy way to record from sdruno using widows 10 and vbcable?
Old 04-14-2017, 1:53 AM
WSJT Home Page
So I got that up and running I think. I have the sdruno using its output as vbcable. wsjt's input as vbcable and speakers out. The water fall is doing something but no sound. Is that normal? I set it to whisper and set the sdruno to the low frequency LW band. How do I know if its working? Do you have to mess with the sdruno every time you want to change frequencies?
Old 04-16-2017, 10:48 PM
Your sound setting look right.
Set it to "JT9 + JT65" and leave the sdruno on 40m 7.076MHz USB at night, 20m 14.076MHz USB during daylight.
At :45 seconds into a minute, the computer stars decoding what it received from :00 to :45
By :55 seconds, you should have decodes if someone is transmitting.
At :00 seconds, responses to the last set of transmissions begin.
If JT9+JT65 works, then switch over to LW frequency and WSPR. Wait. It will come if there is something.
