Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Data Transmissions
Amateur Radio Data Transmissions - For discussion of all modes used to send data such as APRS and packet.
Old 11-12-2017, 2:16 PM
Default Pocsag Numeric and RLL
Hi There,
I am trying to send binary data over pocsag numeric. This works fine until I try to send a sequence 0xfffff (five times 0xF or more).
Because of an unfortunate coincidence, this sequence is sent over the line as 0xffffffff. There is a 10 bit BCH code and a parity included in the codeword.
The receiver however chokes on this because the bandwidth of the receiver can 't go that low. This codeword is sent as carrier + frequency deviation for the channel, so there is no way the receiver can sync again with the transmitter.
I looked at the pocsag specification (*) and there is no mention of RLL (https://en.wikipedia.org/wiki/Run-length_limited) or any other way to limit the number of consecutive zeros or ones transmitted over the air.
Is there anyone who has experienced the same problem and is there a workaround for it?
(*) http://www.itu.int/dms_pubrec/itu-r/...1-I!!PDF-E.pdf
Tags
data transfer, pocsag, rll
