Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio Data Transmissions
Amateur Radio Data Transmissions - For discussion of all modes used to send data such as APRS and packet.
Old 03-28-2018, 9:37 PM
Will001's Avatar
Default What do I need for APRS
Title says it all. I am thinking about getting into APRS: however, I don't want to spend hundreds of dollars. Basically, what is the cheapest way to get into APRS? I've got a laptop computer and several VHF handhelds to use if needed.
Thanks in advance for the tips!
HAM Radio Call: KN4IMX
GMRS Call: WQYT-477
I own too many radios to put in the signature
=a bad day for scanner enthusiasts, and also a bad day for public safety...
Old 03-28-2018, 9:48 PM
iphone with the app will get you on the map
Old 03-28-2018, 10:16 PM
mmckenna's Avatar
If you have a radio and have a GPS, these guys are a possibility:
Byonics
I have built two of their "tinytrack" units over the years, and they work well.
Old 03-28-2018, 11:11 PM
prcguy's Avatar
I got one of these a few years ago and it works very well and is all self contained including batteries. Its only 1watt but into a vehicle mounted antenna it tracks my truck all over the place. If I'm going to areas known for poor coverage I'll take a 40w amp along and it never fails to connect with APRS base stations. It can also be a digipeater. It will be hard to build or buy something else that does all this for $109. https://www.ebay.com/itm/AP510-APRS-....c100005.m1851
prcguy
Old 03-29-2018, 5:39 AM
W9BU's Avatar
Lead Wiki Manager
The smartphone apps use the Internet to inject your position reports into the APRS-IS system. The intent of APRS is local, tactical information using amateur radio. While a smartphone app may "get you on the map", other APRS users will only see your position if they are using the Internet.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
Old 03-29-2018, 6:35 AM
Yes, he was asking bare minimum.
Sent from my SM-G955U using Tapatalk
Old 04-11-2018, 11:49 AM
To add to this, what would one need to do this via SDR? Ive a raspberry PI I would like to do this from at home.
Old 04-11-2018, 4:29 PM
W9BU's Avatar
Lead Wiki Manager
Your SDR would need to be able to encode and decode the Bell 212A (aka ITU V.22) modulation scheme. Then, it would need to assemble/disassemble AX.25 data packets.
Old 04-15-2018, 8:10 PM
If your by chance looking into helping pass traffic to an internet gateway you can get that going for as little as a Raspberry PI, USB sound card and a Scanner or radio with a mic in jack. ($100 or less option)
If your looking to transmit you driving down the highway, or walking you would need to interface a Tinytrak (byonics), or some other type of TNC to decode/encode.
Old 04-16-2018, 11:11 AM
Probably a lot less hassle to just buy a new APRS capable rig. Sell off a couple of your HT's to help fund a new radio.
KD9KSO
Commercial SEL/Instrument
Old 04-16-2018, 2:08 PM
Mobilinkd | Highly mobile packet radio is another option. Connects to your radio and bluetooths to an Android phone/tablet. It gets the GPS from the phone/tablet and displays the received stations there as well using the APRSdroid app.
I have run one for years, started out on an HT but now have it on a mobile radio.
Not the best setup if you are wanting a home station to digi or igate packets. Good for mobile or portable though.
Jon
KF5WUF
Old 04-16-2018, 2:21 PM
TRNcommLLC's Avatar
I run a old Dell D800 laptop using APRSIS32 with the soundcard running soundmodem97 and a TK-7302 mobile on a Workman UVS-300 antenna.
Works pretty well for a Digi/Gateway station.
I had everything laying around.
4n35 iso and 2 isolation transformers into rs232.
I looked at TNCs but wanted to try it first.
Maybe I will buy one for the mobile.
I like the Byonics TinyTrak4
John
KA3OAZ
Old 04-16-2018, 3:33 PM
PLEASE, PLEASE don't encourage people to build RX only Igates as permanent stations. When they are setup that way they break the message capablities as there is no return path to RF if its an RX only Igate. Please see: APRS Messaging EXPLAINED! - APRSISCE/32 The future of Amateur Radio APRS
