Amateur Radio Equipment For general and technical discussion Amateur Radio equipment
Old 07-29-2008, 09:34 PM
Gbcue's Avatar
Send a message via AIM to Gbcue Send a message via MSN to Gbcue Send a message via Yahoo to Gbcue Send a message via Skype™ to Gbcue
Default Yaesu FT-60R - Removing Memory from Memory Bank
Anybody know how I can remove a memory from a memory bank yet still retain the physical memory in the "no bank" area?
Thanks!
Licensed Ham Radio Operator
Yaesu FT-1802M, Yaesu FT-60R, Uniden BC246T, Uniden BC60XLT
Old 07-29-2008, 11:39 PM
stevolene's Avatar
funny you should ask, I ask someone about that the other day, he said I couldnt remove them but I could move them around, I bought an FT60 at a hamfest a week ago in a different area, I need to do the same thing, there is a way you can completely reset the radio, its in the manual, let me know if you learn anything, Im curious myself
Old 07-30-2008, 12:02 AM
selgaran's Avatar
Per the manual's table of contents: Page 32 - "Deleting Memories"
Old 07-30-2008, 01:06 AM
Gbcue's Avatar
I know that, I have this memory duplicated in two banks. I want to rid this memory from one bank yet retain it in the other, so I can't physically delete the memory.
Old 07-31-2008, 08:21 PM
N8IAA's Avatar
Do you have the programming cable? If so, go to http://www.kc8unj.com and download FT60 commander software. Makes it sooo very simple. Don't have the FT60 anymore, or, I would look it up in the manual. It tells how in the memory bank section though.
Larry
Old 11-29-2008, 12:43 AM
Thanks!
Sorry to resurrect an old thread, but I figured out the answer to this question. The way you remove a channel from a memory bank on the FT-60R is add it to the same bank again. In other words, the steps to add a channel to a memory bank is a toggle. Do it once and the channel's in, do it again and the channel is out.
NOTE: You have to be in the memory bank that contains the channels you want to delete. So, if you wanted to remove a channel from memory bank 2, you have to be in memory bank mode and in memory bank 2 in order to remove channels.
Old 02-01-2009, 05:54 PM
Gbcue's Avatar
Anybody have an experience with FT-60 Commander?
For some reason, the program won't write to my radio even though I'm following the directions. It downloaded all the memories just fine though...
Similar Threads
Frequencies for Jeffersonville, IN (Clark County) Choffa Indiana Radio Discussion Forum 34 08-31-2006 12:20 PM
Bank robbers hit Chase again bigbluemsp Michigan Radio Discussion Forum 10 07-21-2006 04:14 AM
help with town/systems FCVPI99 Illinois Radio Discussion Forum 0 12-17-2005 02:47 PM
Pro97 and Pro 96 FCVPI99 Radio Shack Scanners 5 12-17-2005 12:29 AM
My BC210XL just doesn't cut-it anymore CW-Nevada Nevada Radio Discussion Forum 12 05-01-2005 12:30 AM
