Amateur Radio Equipment For general and technical discussion Amateur Radio equipment
Old 06-11-2009, 11:26 AM
Question ICOM IC-2200H Repeater Offset Problem
I am having a problem with my IC-2200H repeater offset. I set the offset, and it works for most of my memory channels, but it seems to not work for the channels in at least one memory bank. I am on a memory channel for a repeater, I hit the "moni" button to go to the input channel, and nothing happens. I can go to the same frequency on a different memory channel in a different bank, and the "moni" button takes me right to the input channel. When I follow the instructions to set it, it works for the channel I am currently on. Then I switch to a different channel, switch back, and the offset is set back to 0.000 again. But when I go to the same frequency in a different bank, I push "set" to see the offset and it's already set.
I read on another thread here about having to have certain things already set before you program memory channels, or else it won't apply to those channels. I am going to try clearing and re-programming all the channels in this bank. Another thought is I have somehow locked out the repeater functions for this bank only, but I couldn't find anything like that in the manual. (Not that it's very clear on most things.) Just wondering if anyone else has come across something like this.
Similar Threads
FT: /FS: Icom IC F3061 VHF Limited Key Pad connerspears Old Classifieds Archives 1 03-09-2009 08:02 PM
UHF/VHF Base & Offset Problem shakey071 Radio Shack Scanners 6 08-21-2008 12:05 PM
ICOM 521 scan problem RFJammed ICOM Receivers 0 03-24-2008 08:31 PM
FS: Icom IC R1500 Receiver Junior08 Old Classifieds Archives 4 03-22-2008 09:21 PM
Help - Battery problem with Icom r5 rboncinelli General Scanning Forum 4 12-03-2006 02:54 PM
