Amateur Radio Equipment For general and technical discussion Amateur Radio equipment
Old 06-30-2009, 04:50 PM
Send a message via AIM to Rob_K
Default Ft-8900
Good afternoon,
I'm new to the hobby and passed my tech exam 2 months ago or so. I picked up an ft-8900 last week and I'm looking to get it up and running.
Initially I'm going to hook this up in my vehicle. I know there is an antenna made by Diamond specifically for this radio and based on reviews, it seems to do an OK job on the 4 bands it covers. I'll probably drill another hole for an NMO mount in the roof.
I'm mostly interested in the 70cm/2m bands but I don't want to limit myself by purchasing only a dual band antenna. On the other hand, I'd like to have one that does pretty good on the 70cm/2m for my vehicle and if I decide to move it in to my home, perhaps then I'd be interested in something to cover all bands.
Also, I'm probably going to need a power supply for my home at some point. I have a Pyramid PS12KX but, that only does 10a continuous/12 surge. Any recommendations on what I should look at?
Thanks!
Rob
Old 07-01-2009, 09:36 AM
Bill_White's Avatar
How many antennas do you want to use?
If you want to get away with using one, your options are limited.
Comet UHV-4 Mobile Antenna
Diamond CR8900A Antenna
This will give you more bands by swapping coils.
Diamond HV7A Mobile Antenna
And this one by changing the tap point.
Opek HVT-400B Mobile HF VHF UHF Antenna
Another option is to use a duplexer or triplexer.
Something like the Comet CF-706A
Comet Duplexers and Triplexers
would allow you to use one antenna for 10 and 6 and another for 2 and 440.
Don’t forget technicians don’t have privileges to use FM on 10 Meters.
According to the specifications the 8900 draws 8.5 amps while transmitting using high power.
Yaesu FT-8900R Specifications
Your Pyramid PS12KX should have no problem running just the 8900.
If you are going to upgrade, I recommend Astron.
Astron Power Supplies
The RS35M will provide enough power to run a modest shack.
I currently have 8 scanners, 3 HF rigs, and a few other accessories connected to mine and it doesn’t break a sweat.
It’s built like a tank and will probably outlast me. R&L Electronics has a couple on the used list for $135.00.
R&L Electronics 800-221-7735
There is no dark side of the moon really, matter of fact, it's all dark.
Old 07-01-2009, 10:07 AM
hmm. I guess I'd be ok with 2 antennas. I think I kind of like the idea of purchasing a 70cm/2m antenna (since those are my primary needs) and then in the future i can add a duplexer and another antenna when I look to play with 6m.
Glad to hear my power supply is OK to use. I actually have the next model up which 12/14a. This will save me a few bucks when I'm getting started and I can upgrade in the future.
Thanks for the detailed reply! I appreciate it.
-Rob
Old 08-16-2009, 09:51 PM
Well, I'm still in search of an antenna. I purchased a Diamond and Comet Quad band but, both were too large to mount on my roof. I also didn't realize the Diamond wasn't a NMO mount.
I was going to pickup a Maldol EX-510 from the local radio shop but they sold the last one and can't tell me when they are going to get another one in.
I've ruled out finding a Quad band that can go on my roof and I can't locate a tri-band either. The Maldol is the only tri band that is a good size for the roof.
Any suggestions or should I just purchase a dual band? 2m and 440 are my primary needs but having 6m available would have been nice.
Thanks,
Rob
Old 08-16-2009, 10:14 PM
Send a message via AIM to fineshot1
I have a comet mobile triband SB-14 for 2m/6m/70cm and it works great. I also run 10mtrs
with a separate antenna(an old motorola low band) and find running 10mtrs separately works
very well also.
fineshot1
NJ USA
Old 08-16-2009, 10:27 PM
very well also.
I should have mentioned I'm looking for something to put on the roof of my Tahoe. I Tried the the EX-510B but I was afraid it was too tall for the roof of an SUV. I also need something that is an NMO as I've already installed the mount in my roof.
Thanks,
Rob
Old 08-16-2009, 10:44 PM
Thanks,
Rob
Just how short do you need it to be? You are going to have trouble finding either a triband or
quad band antenna any shorter than the SB-14 43 inches and still perform well. You must
remember that any multiband antenna is a compramise in performance especially when its
3 or 4 bands and in view of this the SB-14 excells at performing.
EDIT: Most of the Comet line are NMO or can be ordered in NMO.
fineshot1
NJ USA
Old 08-16-2009, 11:07 PM
The height isn't a huge issue. I've been using a mag mount 2m that is as tall if not taller than the Comet. The issue with the height is if I hit something, it is going to rip the NMO out of my roof. The Maldol is a much "lighter" antenna that will be more forgiving if I hit something.
Do you follow my dilemma?
-Rob
Old 08-17-2009, 08:12 AM
2nd EDIT: I was wrong above - the SB-14 is a PL-259 connector mount and would
require an adapter for NMO.
fineshot1
NJ USA
Old 08-22-2009, 07:00 PM
N2JBO's Avatar
I use the Diamond HV-7A with my Yaesu FT-8900R. I have the antenna mounted on the side
at the back corner, of the driverside of my hood, on my 1999 Ford Eddie Bauer Explorer.
Installed the radio without drilling a single hole in my vehicle, my setup work flawlessly.
73 de Dave
Icom 765. Icom 746, Yaesu FT-767, Yaesu FT-757,
Yaesu FT-857D, Yaesu FT-897D, Yaesu FT-101E,
Uniden HR-2600 w/Chipswitch, Kam Plus, PK-232MBX,
Yaesu VX8R. Cushcraft R-7000, BCD996XT,BC 780XLT
Old 08-23-2009, 05:33 PM
73 de Dave
Do you happen to have any pictures of your antenna installation? Wouldn't mind seeing the entire setup too =)
Thanks,
Rob
Old 08-23-2009, 09:06 PM
Default Ft-8900
If you interested primarily in 2 meters/70 cm, you should look at the Larsen NMO-2/70. I have used one for over 20 years on 5 vehicles without a problem. They are practically indestuctable.
Take a look at K0BG's website on mobile radio installations. Its a great website with lots of information along with pages and pages of pictures of installations. The address is Welcome to KØBG's Web Site.
Welcome to ham radio!
73,
Rich, KA4GFY
Similar Threads
Texas Military Activity and Frequencies Firetxmi Texas Radio Discussion Forum 27 08-24-2009 01:49 PM
Active Military frqs. in Colorado Springs Mick Colorado Radio Discussion Forum 46 01-13-2009 08:24 AM
Ft. Meade/Ft. Detrick TRS freqs. & TG's frootydawg Maryland Radio Discussion Forum 3 05-18-2008 11:19 AM
Fs: Ft 8900 123 Old Classifieds Archives 9 05-15-2008 08:47 PM
Sacramento Regional Radio Communications System sacscan Sacramento Valley Area Discussion 631 11-20-2006 05:21 PM
