Amateur Radio Equipment For general and technical discussion Amateur Radio equipment
Old 07-08-2009, 10:34 PM
mlevinedc's Avatar
Send a message via AIM to mlevinedc
Default Smallest 12VDC wall wart?
Hi all
I am in need of a (small, small, smallest!) 12VDC wall wart I can find. I have a recessed 110VAC wall socket that will accept just one grounded plug. I need a tiny PS capable of about an amp or so. Dimensions maybe 2x2x2 inches? or smaller. The desired effect is to keep it flush with the wall. Can anyone point me to a likely source. I only need one piece.
doc
WB2EQE
Old 07-08-2009, 11:10 PM
N_Jay's Avatar
Find one with a cord input.
Some posts can be interpreted as either humorous or insulting
When not sure, always assume humorous
If you only find it insulting you have misunderstood my post or I have misunderstood your post
Old 07-10-2009, 03:00 PM
mlevinedc's Avatar
Default Thanks
Yes I did that, unfortunately it means having the put the box on to of the unit mounted to the wall, which really isn't the goal. I appreciate the suggestion.
Old 07-10-2009, 03:59 PM
gewecke's Avatar
Wink
Originally Posted by mlevinedc View Post
Hi all
doc
WB2EQE
Ok. Try this?
www.jameco.com part#1940774 mean well# GS12U12-P11 12vdc. 1000ma.2.6x1.9x1" Cord is 6' $19.95
Smallest one I could find allowing that current.
N9ZAS.
Search for 419-21210-3 at Mouser Electronics - Electronic Component Distributor. It's not cheap but is the size you want.
Old 07-10-2009, 04:08 PM
rfradioconsult's Avatar
Don't think you will find one that will satisfy your current requirements in that small a package.
Old 07-10-2009, 04:12 PM
gewecke's Avatar
Post
My thought also.
Doc,how much current will your device be drawing? A smaller rating would give you the size you need.
N9ZAS.
Similar Threads
BC246t Wall wart charger mrscanner2008 Uniden Scanners 2 03-02-2009 01:08 PM
Uniden 235/245 Wall Wart bwhite Old Classifieds Archives 5 12-30-2008 02:16 PM
Pro 25 wall wart? investigator16 Radio Shack Scanners 11 04-08-2008 11:31 AM
Wall wart wiring fireEmt5281 General Scanning Forum 7 04-12-2007 10:44 PM
radio shack wall wart monitorboy Radio Shack Scanners 6 09-12-2006 12:19 AM
