Amateur Radio Equipment For general and technical discussion Amateur Radio equipment
Old 07-29-2009, 02:41 PM
Send a message via AIM to Codejockey Send a message via MSN to Codejockey
Default Yaesu VX-8R Audio Level
Hello, I'm new to HAM radio in general, and I have a Yaesu VX-8R that I purchased the other day. I'm beginning to learn the ins / outs of the radio; however, I have one problem with it. I cannot hear the speaker in my Jeep unless it is right on my ear if I'm moving at all. I purchased the radio, the speaker / mic attachment, the GPS attachment, and the GPS adapter. Everything works well, but I had assumed the earphone jack on the right side of the radio would function to power either ear buds or an external speaker in my Jeep. So far I cannot make this work at all.
1. Any ideas would be greatly appreciated on how to resolve this. I thought at first it might only work with commercial am/fm broadcasts; however, in reading the manual, it says if you're in dual band mode you can have the right headphone be channel a, and the left one be channel b, so that tells me it is capable of powering a headphone. I've emailed Yaesu but haven't heard back from them yet.
2. If it only does work for am/ fm commercial broadcasts, I'm thinking it wouldn't be too hard to fabricate a connector to go in the top where the remote mic / speaker unit plugs in. You could then on that adapter create a plug identical to the one it's plugged into for the mic, which would have all but the speaker wires in it, and then next to it a standard headphone jack for separate headphones. Does this sound reasonable, or do you know of any product like it already in existence?
Old 07-29-2009, 02:53 PM
gewecke's Avatar
Post
The jack on the side of your vx-8 is probably a 4 conductor jack,meaning there may be 4 "sleeves on the plug on your speaker mic. If this is the case then maybe your spkr.mic. has an earphone jack on the bottom? This what you would use for an ext.speaker. I have a vx-5 and this is what I have to do in the same instance. A standard 2 or 3 conductor speaker plug will not work properly in these newer mult-function jacks.
I hope this helps. Also I think yaesu may have an optional adapter for the mic. jack to use other speaker mics. or speakers.
N9ZAS.
Old 07-29-2009, 03:32 PM
Okay, I figured it out. It is a 3 conductor jack, and my headphones were fine. Turns out the radio has a setting for this. It was set to speaker meaning no matter what it will output to the built-in speaker or mic speaker (if it's attached). I changed it to Auto and it started working as expected! :-) Thanks for the advice.
Similar Threads
Radio Equipment For Sale KE4ASQ Old Classifieds Archives 68 11-05-2008 09:45 PM
f/s yaesu vx 1r birdman1104 Old Classifieds Archives 1 07-19-2007 04:00 PM
YAESU VX-7R low audio problem? ka9zey All Other Receivers 0 03-25-2007 09:42 PM
FS: Magnesium Yaesu VX-7R with Accessories! kingpin Old Classifieds Archives 2 03-13-2007 12:46 AM
Yaesu VX 5R Thoughts safetyobc All Other Receivers 3 03-01-2007 01:27 PM
