Amateur Radio Equipment For general and technical discussion Amateur Radio equipment
Old 08-25-2009, 08:38 PM
Default icom u82 and icom 91a
If i put the ut-121 digital card in both of those model radios are they secure enough that they can not be picked up on a scanner or would i need a better radio with encrypton on it?? want to use the radios overseas
coecp
Old 08-25-2009, 08:47 PM
wayne_h's Avatar
Forums Manager
Send a message via AIM to wayne_h
Not sure how this ended up in the Database discussion forum so I've moved it to Amateur Equipment.
-Wayne
Please contact me via email for a faster response.
Forum Rules and Guidelines
Old 08-25-2009, 09:56 PM
There are many things wrong with this. But i would not consider D-Star secure in the least bit. There is not much in the way of equipment to monitor it but it's not secure to someone with a radio.
If you want to be secure go with something encrypted.
Old 08-25-2009, 10:16 PM
Caesar's Avatar
Send a message via ICQ to Caesar Send a message via AIM to Caesar
like the other poster stated, it is not secure, anyone with 400$ bucks to blow could easily monitor, however if you are going somewhere besides USA, Japan, Europe, it is very very doubtful there is going to be anyone to listen in. If you are going to be utilizing Simplex only meaning no one is going to be near you it would also work. I would only make this my choice though if you already had DStar equipment which would help you avoid any cost and also if this was going to be a short term solution, if you plan to use this for a while and there are people that want to monitor you, it would not take them to long to get a Icom D-star ready radio...
Uniden: BCD396T, BR330T & BCT-15 (x3)
Icom: IC-91AD & ID-800H (D-Star)
Yaesu:FT-857D
Radio Shack: Pro-163 & Pro-197
Heathkit: HA-10 (1KW Amplifier)
DV Dongle
Old 08-26-2009, 09:01 AM
rfradioconsult's Avatar
Depending where you are going; you may find yourself "donating" a couple of radios to a foreign border agent, or perhaps having to explain why you want to carry such radios into their country.
Old 08-26-2009, 04:43 PM
trace1's Avatar
coecp
The UT-121 is for the IC-91A while the IC-U82 uses the UT-118 and both a for D-STAR only, not secure or encrypted. While it is true that D-STAR can not be decoded by any current scanner on the market any and all other D-STAR capable radios can and will decode D-STAR.
So, if you want or need encryption you had better go with something else and if you haven't already done so, I'd check with the laws, rules, and regulations regarding the use of radios in which ever country it is that you're planning on visiting.
Cha bhi fios aire math an tobair gus an tràigh e.
Similar Threads
WTB Icom Software for V8 and U82 peterjmag Old Classifieds Archives 0 02-01-2009 05:04 PM
FS - Icom U82 w/ the D-Star Module Tom_G Old Classifieds Archives 2 01-31-2008 07:32 AM
Icom U82 needs antenna rescuecomm Antennas and Coax Forum 0 09-11-2007 07:35 PM
icom u82 satob1 ICOM Receivers 4 03-28-2007 10:53 AM
