The FT-840 was my first HF radio. It worked well for the most part, although its receiver did leave a lot to be desired. It's a no-frills rig, but with a good antenna will get you out on the bands once properly licensed. As for the speaker, it's an easy fix. Pull the top cover off and replace the speaker with one of a similar size and ohm rating. Resolder the connecter wires and attach the connector back to the RF board. Should take less than 10 minutes to fix if it's just a busted speaker and not a problem with the internal audio circuitry.
73 de James K2QI
