Amateur Radio Equipment For general and technical discussion Amateur Radio equipment
Old 11-01-2009, 04:38 PM
RadioDaze's Avatar
Default Question for Yaesu FT-60R Owners
I just read 22 pages of reviews on eHam.net and found no mention of this:
Do you find your radio to be "tippy" i.e. even if it's standing up on a nice flat, smooth surface, it is REALLY prone to falling over backwards?
Old 11-01-2009, 04:51 PM
gewecke's Avatar
Smile
Well,the VX-5R is but that never bothered me. I put in a foam can-koozy to keep it upright.
Maybe you could do the same with the FT 60?
N9ZAS
Old 11-01-2009, 07:46 PM
RadioDaze's Avatar
I'd feel pretty silly dragging the foam thing around with me. Didn't seem to bother me in college, although back then I would rather my radio tip over than my beer get warm.
Old 11-01-2009, 09:10 PM
DonnieDog's Avatar
Yeah I agree, mine is shaky and tipable (<word?) LOL! Other than that I love my FT60!!!
RS Pro-197
Yaesu FT-60R
Sometimes things are better left unsaid.............
Old 11-01-2009, 09:45 PM
RadioDaze's Avatar
Tippable?
After I get my first scratch or dent, I might craft some tiny feet for it. Like on the back edge. Don't know where I'll find shoes that small, though.
Old 11-02-2009, 02:06 AM
Find the perfect location on your desk. Add a few drops of super glue. No more tippable FT-60.
KF4UUZ
Pro-106 X3
FT-60 X3
VX-170 X2
Sangean Super ATS 909
Old 11-02-2009, 08:29 AM
Yes, but only because of the long diamond whip that it usually wears.
I've never mounted the factory whip, but I imagine if I did, it would have a lot more balance when sitting on its arse on the desktop.
Old 11-02-2009, 11:08 AM
gewecke's Avatar
Good point!
N9ZAS
Old 11-02-2009, 05:10 PM
I made a stand for mine using an article I found on mods.dk. I didn't use the same material that was listed, but it does keep the radio standing.
Old 11-03-2009, 12:19 PM
RadioDaze's Avatar
Sorry SIG, but I couldn't get access to that page. But I'm glad, I guess, to hear that others have the same problem, and I don't have a case that's out of tolerance.
The problem appears to be that the front edge of the case has two little molded projections to make contact with the surface, but the point of contact at the rear is the battery retaining clip. So it's a 3-point footprint. (Even thought the battery clip appears to provide 2 points, they are close enough together as to be as good as one, compared to the front. And since the clip curves upward at the back, the radio wants to "roll" back on it after it leans past a certain point.)
The solution I'm going to explore is to find the correct thickness of sticky pad to place on the aluminum edge of the chassis that extends from the sides of the battery clip. If the thickness is just right, it will match the height of the front support nubs, and provide a 4-point contact.
Time to get out the feeler gauges and the digital micrometer! I'll share photos if I come up with something useful. Why they didn't build this solution onto the chassis itself is beyond me.
Old 11-09-2009, 05:00 PM
Smile another thing you might try.
I went to Walmart and found plastic picture frames that do the trick. Use the belt clip on the back of the radio. Just clip it over the picture frame Some I found were tilted some stood straight up. My 4 HT's and 3 handheld scanners set on them. Cheap radio stand.
Old 11-09-2009, 08:03 PM
RadioDaze's Avatar
That sounds like a pretty good idea. I might even try that for the Uniden 330 on my nightstand. But I'd like a little more portable solution for the HT. When you look at the bottom, there is a little raised portion on the metal chassis on each side of the battery clip hinge, at each end of the hinge pin. If that raised area continued to the outer edge of the bottom on each side, the problem would have been solved. So the trick will be to affix something to fill in that height gap, which is about +/- 1.2mm. They could have easily done it in the original design, but since this radio has been around for a while, I can understand why they don't want to re-tool it. I'm betting on a little piece of plastic and some JB Weld to fix it... when I get around tuit.
Old 11-10-2009, 01:31 AM
N1BHH's Avatar
Send a message via AIM to N1BHH Send a message via MSN to N1BHH Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
I put mine in a coffee mug. I don't drink coffee and never put liquid in them. I have a couple that I use, one for my FT-60R and one for my Pro164. Just put a little padding in the bottom to raise the speaker up a tad and you are all set.
WQBX787 = GMRS
Pro2055 Pro94A Pro2006 Pro2015 Pro2021 Pro164
Yaesu FT-60R, 8000R & 8800R, Motorola MTX9250, Alinco DR635T
