Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
Old 04-12-2011, 11:07 AM
Default Alinco dr-600 internal battery
does anyone know what kind of internal battery the Alinco dr-600 has. mine is dead and wanting to replace it.
Old 04-12-2011, 11:39 AM
I dont have this radio but they are usually the solder tab type - like a CR2032 or similar but with solder tabs
so they can be soldered directly to the radio pc board.
fineshot1
NJ USA
Old 11-06-2011, 1:51 AM
Default Alinco DR-600T Battery Replacement
The Alinco DR-600T uses a BR-2032-1F2 Lithium battery. This is a standard BR-2032 coin type battery with attached tabs, and insulation around the edge. The new model number BR-2032-F2N has replaced the older model number.
While I was able to find plenty of (tab-less) CR-2032 batteries locally, a review of a Panasonic data sheet indicated that a different chemistry is used in the CR series, and that the original BR chemistry seemed better suited to the harsh environment in my vehicle.
The BR-2032-F2N batteries (former BR-2032-1F2) can be obtained from major electronic supply outlets. My most recent one came from Digi-Key out of Thief River Falls, MN. My last one (installed in 2002) came from Mouser Electronics. Allied Electronics also carries them in their catalog.
I would have liked to have added a battery holder so that I wouldn't have solder in a new battery down the road, but I couldn't find one with the proper dimensions and thin enough to hold the battery without shorting out after adding the shielded back to the control head (I use a separation cable in my installation).
I've attached a photo of the inside of my DR-600T control head showing the BR-2032-F2N in the upper right hand corner.
Hopefully, this information will help anyone looking to replace this battery in the future.
Old 03-30-2012, 3:03 PM
Unhappy Alinco DR-600 Battery
I sent it off and had the battery replaced once because I couldn't find the correct battery with solder tabs.
Battery died again in 2 years and I took it apart to find out the man who replaced it did so with a smaller battery. So I found bought and replaced the battery myself checking the polarity before connections. Now my entire display is nothing but a set of vertical lines. Radio will not work. Any ideas how to fix this or should I toss this one and buy a new one? Thinking with all those other exposed connections my piece of Scotch tape I put under it wasn't thick enough. May have shorted something out.
Old 03-31-2012, 8:24 AM
Did you do the master reset after replacing the battery?
fineshot1
NJ USA
Old 04-05-2012, 8:57 AM
Default DR-600 battery
After I posted the message I realized there was a master reset on the radio and recalled hold the function key down during power up and that did resolve the problem. :-)
If you come to our area you can find me usually monitoring the 146.64 Fort Smith Amateur Radio Club repeater located in Poteau, OK.
My DR-600 runs on solar power and a battery bank. I write my novels and edit video production in my "command room." ;-)
Thanks for posting.
Old 04-08-2012, 9:02 AM
Thanks for posting.
You are most welcome
happy easter/passover
fineshot1
NJ USA
Old 02-18-2016, 7:26 PM
Default Alinco DR600
Changed the battery and got the same bunch of vertical lines. Thanks for the function reset. I was about to buy a new radio.
