Amateur Radio Equipment For general and technical discussion of Amateur Radio transceivers, repeaters and receivers.
  #61 (permalink)
Old 03-02-2012, 4:06 PM
GKolo's Avatar
Listened to a tornado touchdown just south of me, I had my lil radio in a Go Bag just incase i had to head out.
Sorry not a VOLS fan...lol
''Life's tough ........ it's even tougher if you're stupid.'' -- John Wayne
  #62 (permalink)
Old 03-05-2012, 12:39 AM
bob-the-scanner-man's Avatar
I went to a hamfest yesterday and they had the UV-3R for $60. They had a few display models so I finally got to play around with one. Very neat little rig and much smaller than I was expecting. I passed over picking one up yesterday since I can get a better deal buying directly from China on Ebay; ~$50 for the radio and a speaker mic.
When I buy one I'm going to upgrade the antenna and toss it in my go bag.
Radioshack Pro-96
Uniden BC-246T
  #63 (permalink)
Old 03-05-2012, 5:36 AM
Don't forget to buy the programming cable, too.
  #64 (permalink)
Old 03-15-2012, 2:23 AM
Anyone here interested in the KYD NC-5H radio ?
  #65 (permalink)
Old 03-26-2012, 11:25 AM
Originally Posted by BrickOLore View Post
I am guessing that the UV-5R will have alpha tags. Based on the storms today, I suspect you got to listen to the Skywarn net this afternoon. (And Go Vols!)
You can only edit the alphatags via the serial interface. The software limits you to 6 characters, but you can manually edit the .dat file and do 7.
Brick O'Lore: Baofeng UV-5R: Alphatags 7 Characters Hack
  #66 (permalink)
Old 04-06-2012, 2:04 PM
Default Baofeng UV-5R programming question
Is it possible to program this radio to work with a Motorola LTR trunking system?
I am an authorized user but was looking to get another radio that is lighter. Can't ask the Moto tech this question and my department wouldn't buy one, so this would be a great option.
I have the frequencies needed, but with an LTR system, DPL or CTSSS are not needed. How would it work with talkgroups ?
If this is not possible with this inexpensive of a radio, then I understand, just a thought from a newbie in this game.
thanks
  #67 (permalink)
Old 04-07-2012, 8:12 AM
thanks
No..................not going to work on a trunked system.
  #68 (permalink)
Old 05-05-2012, 2:53 PM
FoeHammer's Avatar
Im going to pick up a UV-3R mark 3 ,...Ill be programming it manually
I have used the puxing 777 , i dont know how similar it will be , but my question is
is there a good step by step instructions online for manual programming... & can all the menu selections ,..like say for example the narrow/wide selection ,...can this be applied to specific stored channels individually ?
So could i store the frequency in chan one ,...with a narrow setting & channel two with a wide setting etc ?
  #69 (permalink)
Old 12-10-2012, 12:45 AM
Default alpha
i got the radio programmed just need the alpha tag! my programming wont let me just im sure someone has a trick... all help needed thanks all..
  #70 (permalink)
Old 12-10-2012, 8:12 AM
You need the programming software to create the alpha tags. There are several places on the web that you can download.
Have fun!
Randy
  #71 (permalink)
Old 12-13-2012, 11:38 AM
Does anyone know what the setting should be on a UV-3R in the menu mode.
  #72 (permalink)
Old 12-13-2012, 11:50 AM
Setting for what - specifically ?
Randy
  #73 (permalink)
Old 12-15-2012, 8:15 AM
Unhappy Codes
RX, TX, VOX,POWER, DW,STEP, OFFSET, SHIFT, STE, W/N, TOT, SCANM, RELAYM, BCLO, PRI. HAS 19 MENU CODES BUT THESE I AM NOT SURE WHERE TO SET THEM, Thank You
  #74 (permalink)
Old 12-15-2012, 6:43 PM
KD8DVR's Avatar
My UV3r does NOT have alpha tags. The software has a spot for "future" use, but last I heard they don't have that capability.
John
Amateur: KD8DVR
  #75 (permalink)
Old 12-20-2012, 3:20 PM
GKolo's Avatar
Whats the best software to download, I had to get a new laptop and need to download it again.
LinkBacks (?)
LinkBack to this Thread: http://forums.radioreference.com/amateur-radio-equipment/211491-baofeng-uv-3-a.html
Posted By For Type Date
Google INTERIA.PL - szukaj: oprogramowanie baofeng This thread Refback 02-06-2012 3:53 AM
