dieseldriver2003
Greetings All!
I am relatively new to the Amateur hobby and have been tinkering with my new Yaesu FT-857D which I have purchased back in March of this year.
First mod that I did was to open up the TX range on the radio via Jumper modification. Later I found out that my autotune function to control the ATAS-120A is not working - though the manual tuning works fine.
I am looking to un-do this mod because of this issue, but, did not note the original factory jumper position to go back to where it once was.
Does anyone know which jumper positions (I believe it was just two jumpers) should be shorted and rest left open?
Also, does the radio holds any SWR mapping like a Tuner that gets wiped out when you perform the factory reset via [V/M]+Power sequence?
Thank you so much for your time and 73
Pete KC2ZXL
Pete KC2ZXL
