Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
Old 09-20-2011, 7:10 AM
Default Dead Alinco DJ-G7
I have an Alinco DJ-G7 that wont power up. I have had some problems with it in the past, where I had to press the power-on button several times before it fires up, but now it just want power up. Is there anyone out there, that has had the same problem, or anyone that got a sullution? I have tried to remove the battery, but that did not help at all...
_
SonicN
Old 09-20-2011, 7:46 AM
Not to be smart or make anyone out to look bad. However if you've had problems in the past where you've had to hit the power button a few times in order to get it to turn on, then I might try replacing the power button.
Old 09-20-2011, 8:46 AM
;-) Don't worry. You are smart, and you are not making anyone look bad
I realised that I had a battery-case for this radio. A case where you can insert AA-batteries. And with this attached, the radio fires up right away. So it might be orignal battery that is dead, or at least the problem. But anyway.. thanks anyway
_
SonicN
