Amateur Radio Equipment For general and technical discussion of Amateur Radio transceivers, repeaters and receivers.
Old 09-26-2012, 11:42 PM
KB0VWG's Avatar
Exclamation Kenwood Thf6a Issue
Has anyone had the problem of Thf6a battery getting stuck to the radio after it has finished charging?
I haven't had an issue with it until now. It usually slides off really easy. I wonder if it baked itself together.
kb0vwg
wqoi992
Old 09-27-2012, 5:58 AM
gewecke's Avatar
Question
kb0vwg
wqoi992
Is the battery getting hot during its charging cycle? It shouldn't be.
73,
n9zas
Old 09-27-2012, 8:28 AM
KB0VWG's Avatar
Exclamation Not sure
I plugged it in and left for work that day, So I was not sure if it got warm or not. The charging lights did turn on and they were off when I arrived home.
kb0vwg
wqoi992
Old 09-27-2012, 1:04 PM
gewecke's Avatar
Thumbs up
Battery still stuck? Might sound odd but try some dish soap around the edges.
73,
n9zas
Old 09-27-2012, 7:52 PM
KB0VWG's Avatar
Thumbs up I got it
As I look at the battery once i did get it off the radio seems like it buldged out just a slite bit, I can slide on a second battery with no problem. That battery still holds a charge but I think it is time to toss it and get a new battery.
kb0vwg
wqoi992
Old 09-27-2012, 7:59 PM
gewecke's Avatar
Exclamation
kb0vwg
wqoi992
Check out your charger too, because it shouldn't have allowed your battery to overcharge! I wonder if a cell burst inside your pack?
73,
n9zas
Old 09-27-2012, 10:06 PM
KB0VWG's Avatar
Smile Yep
I did charge my second battery with the same charger and it worked fine.and that was the origonal battery, The replacement was from i believe American battery supply.
kb0vwg
wqoi992
Old 09-27-2012, 10:37 PM
Fuzy_GSXR1000's Avatar
Send a message via Yahoo to Fuzy_GSXR1000
Wow glad your ok there I would be sick if I cooked the radio!!!
Michael KD2CUD
Radio Shack Pro 197
Kenwood TH-F6A
