Amateur Radio Equipment For general and technical discussion of Amateur Radio transceivers, repeaters and receivers.
Old 10-02-2012, 6:04 PM
Default PX888K Help!
Hi I am brand new to the Ham world. I recently bought a px888k it worked fine for a few days. I plugged the radio into the computer to program it and now its locked up and won't do anything. The left side of the screen says "cal" no where in the book does it say anything about "cal". If anyone has any information on how to unlock this, or is there a factory reset? The book that came with the radio does not have very much information.
Old 10-02-2012, 8:53 PM
KD8DVR's Avatar
Turn radio off, hold the MENU key while turning the radio on, then press enter when it says RESET?
Hopefully that will bring it back
John
Amateur: KD8DVR
Old 10-07-2012, 9:06 AM
No luck, still stuck no matter what I do. I e-mailed Puxing and their response was hit the escape button. None of the buttons do anything,hitting escape certainly does not do anything.
Old 10-07-2012, 9:20 AM
here a screen shot of where the radio is stuck.
Old 10-07-2012, 9:06 PM
KD8DVR's Avatar
Sorry that didn't work. I don't know what to tell you at this point.
John
Amateur: KD8DVR
Old 11-12-2012, 2:57 PM
n1nte's Avatar
Did you ever find out how to get the radio out of this mode? It appears to be calibration mode (CAL in the display).
Old 11-12-2012, 4:27 PM
KD8DVR's Avatar
Perhaps with software and a cable could reprogram a clean file, but read it first, to see if some odd setting has been made.
John
Amateur: KD8DVR
Old 11-13-2012, 1:25 PM
I have found you get into that mode by pushing the bottom right '#' button. To get back to normal you just push the ESC/M button to cycle through VFO and Memory Mode as usual.
Not really sure what that mode is for. Like was said there isn't any information in the manual. At times I accidentally hit the button and it goes into that mode, usually at inopportune times. Never had a problem getting out of it.
Looking at your picture it appears to be in dual watch mode. I'm not sure if you can have just one "band" in cal and the other not, as with other modes, but try pushing Enter to switch to the B "band". If that works try pushing the ESC/M button.
The only other explanation I can think of is that by connecting it to the computer it messed something up.
Old 11-13-2012, 2:49 PM
Default Solution
You need to change the Work Mode-A and Work Mode-B settings in the Optional Features menu from VFO to Ch. Name. [See image] This will set the radio to power up in the correct mode to display the channel alias names.
Pressing the # key sets the radio to the call channel. You can change this by going to the VFO/Call menu. You will notice that the two frequencies you had on your display before are shown as VFO A and B.
Please feel free to contact me if you have any additional questions.
- Rob
Old 11-16-2012, 3:19 AM
Hello all,
I receive my PK888K 1 month ago, and all is OK before I plugged the radio into my computer. Since I do its locked too. Not any push-button are active. I can push MENU btton, but I cannot enter into menu systeme.
I tried the solutions given above, but none Resolves the problem.
Kind Regards
JC
Old 11-16-2012, 5:44 AM
Originally Posted by F8DDE View Post
Hello all,
Kind Regards
JC
If you download v1.01 of the software there is a setting that isn't in v1.03 called Manual. It is located in the Optional Features menu. When checked off it is supposed to disallow keypad programming to comply with FCC Part 90 rules here in the US. If you check Manual on then it will allow keypad programming. Again, this setting is for some reason only in v1.01 and not in v1.03.
To obtain this software if you can't find it anywhere else online you can go to the files section of the PX-888K Yahoo Group: Puxing PX-888K Yahoo Group
- Rob
MURS Radio
http://www.murs-radio.com
Old 11-16-2012, 9:43 AM
Many thanks Rob to your help.
Now my transceiver work again.
73
Kind Regrads
JC
Old 11-16-2012, 11:38 AM
You're welcome, glad to help!
- Rob
MURS Radio
Old 11-16-2012, 8:05 PM
Fuzy_GSXR1000's Avatar
Send a message via Yahoo to Fuzy_GSXR1000
Good stuff here!!! This is like my club but just online...LOL they help me and people here help me!! I love this hobby!!!
Michael KD2CUD
Radio Shack Pro 197
Kenwood TH-F6A
Old 11-18-2012, 5:05 PM
KD8DVR's Avatar
I have a suspicion that that option is no longer supported in later models. My radios do not lock out the keypad programming, when used with the 1.01 software. Perhaps, the function is still supported; but in a yet-to-be-released software version.
- Rob
John
Amateur: KD8DVR
Old 01-29-2013, 2:07 PM
Default HEEEEEELLLLP
Hey I really need help im like a noob in this type of field Programing/installing I recently received a puxing px-888k just to be straight to the point I need help with everything. I have and know all the frequencies I need I just cant seem to download the software and program it manually or through the computer please here is my phone number serious callers only I need to have this radio up and running 347-585-9875
Old 03-05-2013, 7:02 AM
In structions for resetting the HT are on page 13.
You have 2 options.
VFO or FULL
BOB
AF2Q
Old 04-19-2013, 9:12 AM
Default same probleme with my puxing !!! help
Dear Om
i have read your problem about puxing 888 k
because today i have the same probleme with this transceiver !
my puxing also in look with call !! before i had plug this to my pc ...
Do you have an solution for this ,
Thanks a lot
best 73
Roger
From France
Old 04-24-2013, 1:49 PM
N8KVB's Avatar
A new software has to be used to fix the radio, it is locked.
It does require a computer cable and software though.
Software and more info can be found here:
http://groups.yahoo.com/group/px-888k/files/
