Amateur Radio Equipment For general and technical discussion of Amateur Radio transceivers, repeaters and receivers.
Old 12-22-2012, 7:36 PM
Default Kenwood tmv71a frequency mod 480 MHz tx
Hello,I have a Kenwood tmv 71a and I need it to tx up to 480 MHz .
I have seen the mods to take them to 470 MHz.
Can anyone help please .
Wayne
wayneabird@mail.comp
Old 12-23-2012, 12:37 AM
Even if you can get it to transmit up to 480MHz will it be happy doing it, as power will drop very fast once you leave the ham band. I suggest getting a properly designed commercial radio to operate in commercial spectrum, NOT ham gear.
Interoperatablity is not a technology it is an attitude!!!
Old 12-23-2012, 2:13 AM
MTS2000des's Avatar
This radio will not transmit above 470MHz. Not gonna happen.
Get a real LMR/PMR radio if you need to transmit there.
All opinions, statements, posts, or information made public are those exclusively of the author, and not those of his employer, contractors or associates.
Old 12-23-2012, 3:00 AM
Default Kenwood tmv 71a
Thanks for the info , but still does not help me.
One radio takes a lot less room , have the option of a alinco or icom but have this 71a so if anyone knows how to tx up to 480 MHz please contact me.
Wayne
Wayneabird@gmail.com
Old 12-25-2012, 11:55 AM
KE4NYV's Avatar
Send a message via AIM to KE4NYV Send a message via Yahoo to KE4NYV
You already got your answer. Obviously it's not the one you wanted. Just because you keep asking doesn't mean you're going to get the answer you want.
Jason Rausch - Amateur Radio Callsign: KE4NYV
RPC Electronics, LLC
Old 12-25-2012, 6:21 PM
Good on ya Jason, didn't know that 2 reply's are gospel!!
Old 12-26-2012, 8:35 AM
Based on information from the other various sites, the 71a will not transmit above 470Mhz. The VCO is just not capable of doing that even with the MARS/CAP modification. Hope this helps you.
Randy
Old 12-26-2012, 1:21 PM
Two replies are not always 'gospel', but sometimes they are. Don't know what to believe? Research it for your self then you decide. In this case those two posts were 'gospel', just can't do it, sorry.
- 'Doc
Old 12-26-2012, 2:22 PM
Skypilot007's Avatar
I'll make it three...
These are great radios. I'm happy they work on GMRS with the MARS mod. Even on 460MHz power is down to 40 watts or so with a good swr reading. I haven't put one on a service monitor to see what it does receive wise on 460MHz but I'll bet there is some compromise using it out of band. 480MHz is a major stretch. You're talking 30MHz outside the designed original operating band. Most modified commercial radios will only go 10 MHz before performance starts to fall off. Even if you were to do some hardware modifications to make it to 480MHz or above you would likely loose the 440 Ham band as a result and the radio would probably need a full alighnment with a modified procedure to account for the upward shift in range. I'd be happy with what you got and get a comercial radio for 480MHz, they're easy enough to find. Make some room for it.
Old 12-26-2012, 3:07 PM
I have a TMV 71A on the bench and after a lot of testing and confermation with a senior tech at Kenwood, this radio will not transmit above 470mz even with the MARS/CAP mod as it is designed as an Amateur radio for use in the USA.
Also, if you really need a radio that will do what you want, then you are going to have to look at the newer very expenceive commical radios from Motorola or Harris to do this.
Here in the USA, 480mz is used by TV broadcasters and is off limits for private use.
Old 12-26-2012, 3:11 PM
KE4NYV's Avatar
The only reason I even opened up this thread to read it was because I just recently purchased a V71A for my new Jeep and I would like to open it up for extended transmit. Having said that, in general, the VCO's on these amateur transceivers will really only stretch about 8-10 MHz in either direction. Even at that, the power goes way down and you might even get some nasty harmonics as a result of it being way out of it's intended pass bandwidth.
Old 12-26-2012, 7:03 PM
Cheers everyone , I will get rid of this one week old v71a and go for an icom or alinco .
Wayne
Old 12-28-2012, 10:12 AM
rapidcharger's Avatar
Location: Bringing you happy thoughts and crunching the numbers daily since 2012
Send a message via ICQ to rapidcharger
They probably won't do it either.
Old 12-28-2012, 11:11 AM
You say you are in Australia, if you try to pick up ANY dual band radio that is normally marketed in the USA as a dual band Ameture radio, then you will never be able to do what you are looking to do.
As stated above, the 480mz band is used by TV broadcast in the USA.
All dual band Ameture radios that I have seen have been a real wrok to get then to transmit up to 468.000mz and then they go total dumm above that.
You need to look at the radios that are made for your area.
Good Luck
Old 12-28-2012, 3:24 PM
Thanks everyone , we have found what we are looking for, the radio is from china and it does 40 watts on 480 MHz and a dual bander.
The radio is a anytone at588 v/u, good on ya china.
Cheers
Wayne
Old 02-19-2013, 3:05 PM
Buttabean's Avatar
Question Dual Band?
Cheers
Wayne
Have u purchased this radio yet cause it isnt a dual band? It is listed as a: "Anytone AT 588 mobile radio, and it is not a dual band radio. if you like the dual band radio, you can choose BAOJIE BJ-UV55 OR Anytone AT-588UV OR WOUXUN UV920R." I was looking to buy a cheap Dual Band mobile to use as a base & tha only one i found to do it was the TC-VU55 from china but after reading the review on eham about it im not gonna waste my money on it. I thought the anytone at588 was a dual band also but its not. U gotta specify which band u want it for when u order it. But have u bought this yet by chance?
Amateur Radio plays a vital public safety communications service with tremendous potential when all other forms of radio communication fail, especially in emergencies.
Greg Walden, U.S. Congress
Old 02-19-2013, 3:52 PM
More than thirty years ago Kenwood's ham radios in VHF and UHF were well known for their designed-in lack of operation outside the ham bands. I had a matched set consisting of a 201 and a 401 in my car at the time and I guarantee you that all they did was 144-148 and 420-450, period. It was much later that the more flexible tuning radios began to appear.
Old 02-20-2013, 12:11 AM
The nice thing about these older radios was they didn't receive intermod. In 91 I was staying in NYC, & had a Kenwood 731. Not one chirp the whole summer I was there.
GARY N4KVE
Old 02-20-2013, 1:53 PM
robertmac's Avatar
Just because most people speed doesn't mean it is legal or should be done. Same as illegally transmitting on a modified radio. Might come back to bite you in the rear as it has with a number of truckers illegally using modified amateur radio equipment in Canada. And in Canada, these truckers continually are on frequencies they are not licensed for and are interfering with EMS comms..
Old 03-08-2013, 11:57 AM
MrQ MrQ is offline
Good Luck
Many years ago the FCC allowed several major city areas to use the first few "channel" slots ( chs.14-16) for public safety ops. For example, Boston uses this freq band as well as surrounding communities on a network that allows all surrounding cities to Boston to be linked for intercity ops (PD only). I believe this was allowed because years ago the UHF TV band was not growing in use as expected so the first few channel allocations were allowed public safety use in several large cities across the US. Example: Brockton, MA uses 483 MHz and I believe this is the highest "TV Band" freq used in this area for public safety use.
