Amateur Radio Equipment For general and technical discussion of Amateur Radio transceivers, repeaters and receivers.
Old 01-17-2013, 11:30 AM
Default Baofeng uv 5r PTT ID
Before I commit to buying, quick question? Does this have the ability to transmit a radio id number? Or a PTT ID NUMBER?
Old 01-17-2013, 1:41 PM
robertmac's Avatar
Question Cheap probably doesn't
I don't think it does but not certain. Does have stupid roger beeps that can be turned off thank goodness. But every radio does have it's own "fingerprint" when a transmission occurs.
Old 01-17-2013, 2:06 PM
What kind of PTT-ID? MDC? DTMF? Fleet-sync? Need more info
Interoperatablity is not a technology it is an attitude!!!
Old 01-17-2013, 2:24 PM
MDC
Old 01-17-2013, 5:03 PM
Default Baofeng UV-5R transmitted ID
Menu item 15 is ANI (automatic number identification) which can only be set via software, not from the front of the radio. I checked it on my radio and indeed it can not be changed from the keypad. My unit was shipped with ID 80808 installed.
Old 01-17-2013, 5:11 PM
Ah!!!! Thank you sir, your the best no wonder I was stumped
Old 01-20-2013, 9:14 PM
KD8DVR's Avatar
The Baofeng uses DTMF as its ANI. It only sends 0-9 and a-d as dtmf tones. The only alphanumeric radios are the Puxing px-888k and the tyt dualband radio which uses MSK that is different from MDC1200
John
Amateur: KD8DVR
Old 01-20-2013, 10:31 PM
rapidcharger's Avatar
Location: Bringing you happy thoughts and crunching the numbers daily since 2012
Send a message via ICQ to rapidcharger
I'll also add that the Baofeng sends the DTMF ID so painfully slow that it will probably screw up any repeaters you try to use it on that are controlled by DTMF. Not to mention, annoy everyone else.
