Amateur Radio Equipment For general and technical discussion of Amateur Radio transceivers, repeaters and receivers.
Old 02-04-2013, 4:19 AM
Spankymedic7's Avatar
Send a message via Skype™ to Spankymedic7
Question BAOFENG UV-5RA...Can the 5/2 tone mystery be decoded?
Hi to all,
I got the Baofeng UV-5RA HT for Christmas, programmed it with the software, and thought that all was well...until I discovered that it is capable of decoding 5/2 tone, now I'm on a mission. See, I'm on a local fire department, and would really like to find out how to program this radio to decode my department's pager tones. As anyone else can attest to, the manual that accompanies this radio is pretty much useful only for starting a good fire in the fireplace, and I haven't been able to find out any useful info elsewhere on the web regarding the 5/2 tone feature of this radio, other than it is capable of doing it.
So, I come to you, my fellow HAMs, GMRS'ers, and other assorted radio enthusiasts...can you help me solve this issue?
Thanks in advance!!!
Cory-
Critical Care Paramedic
WI9EMS
Old 02-04-2013, 5:07 AM
W8RMH's Avatar
deleted
BCD396XT - BCT15X (Feeder) - BCT15 - Bearcat IV - Yaesu FT60R
Columbus Police Citywide Dispatch
Old 02-04-2013, 9:28 AM
Just out of curiosity where did you hear this? I have never seen anything about this topic nor have I seen this capability in the Baofeng or Chirp software.
Randy
Old 02-04-2013, 9:34 AM
n8zcc's Avatar
I Googled to see what a 5/2 tone is, didn't find out what it is but found an add for Wouxun indicating 5/2 tone.
Wouxun 699E 136-174MHz 5/2 Tone + 1750Hz KG-699E VHF 136-174Mhz [] - $99.50 : Buy Two way radios, Security 2 way radio accessories and commercial handhelds!
What is a 5/2 tone?
73 de n8zcc
Bytes are cheap so drop those acronyms.
Old 02-05-2013, 9:44 PM
I've seen this capability advertised in one or two advertisements/brochures for this radio. Also, you can see the display on the radio, in the lower left hand corner shows the "5T/2T" indicator, which can be found on the miklor uv-5r help page:
Baofeng UV5R FAQ UV-5R
I've heard that there are firefighters that do use this radio for the reception of paging purposes, just haven't been able to figure out how to program it to do so.
Cory-
WI9EMS
Old 02-05-2013, 11:41 PM
Now I know what you mean. The radio itself does not have any two-tone paging decoding capability. The firmware is not programmed for that feature. Yes it is on the display but it never appears. This is probably just a common LCD panel that is used in other radios. Now that isn't to say that at some point Baofeng would offer an upgraded model that offered two-tone paging capability. It just isn't in there now. And since the radio firmware can't be flash updated, current radios will not have that feature.
Randy
