Amateur Radio Equipment For general and technical discussion of Amateur Radio transceivers, repeaters and receivers.
Old 02-05-2013, 11:44 PM
MarcusDude's Avatar
Default Programming repeaters on Baofeng UV-5RA
I am having trouble programming repeaters into my UV-5RA. I put the radio in frequency mode, and program the frequency (146.910) with an offset of 00.600 and - shift direcion and then save it to a memory channel. When I put it in channel mode, there is no "-" so I push the *scan button and it shows the same frequency (146.910) so it is effectively in simplex mode. I went into the menu and it showed the shift direction as "-" but the offset as "00.000". I put it back in frequncy mode, the frequency 146.910 is displayed with a "-" above it. I push the *scan key and it shows 146.310. Does anyone know how to get it to do that in channel mode? Can I program repeaters into memory channels in this radio with just the radio, since I don't have any software or programming cables.
73's KC9YEJ
Old 02-06-2013, 5:14 PM
MarcusDude's Avatar
Nevermind, I figured it out.
Old 02-06-2013, 5:18 PM
All else fails, read the directions.
Old 02-06-2013, 6:14 PM
programming software.
makes things 100 times easier
W2IBC 147.435 repeater Anderson,Indiana Echolink W2IBC-R Node#699227
100% Linux baby! get linux -> http://www.debian.org/
