Amateur Radio Equipment For general and technical discussion of Amateur Radio transceivers, repeaters and receivers.
Old 02-21-2013, 9:04 PM
Default IC-T2H memory retention
Does anyone know for sure if the Icom IC-T2H requires the batteries to be installed (and not dead) for the memories to be retained over time? I want to keep my low self discharge NiMhs in the radio without using it very often but be able to pretty much count on it working when I do need it, but it has been suggested that the radio might constantly draw a small current to maintain the memories,and therefore the charge would not last over a long period of time... I was not told specifically for this radio that it does this but that some handhelds do that.
Radio monitoring and scanning since the 60's. Visit my Nova Scotia radio site at www.marscan.com
Old 02-21-2013, 10:59 PM
k3cfc's Avatar
I don't know about this one but my ic t7h will flatten the battery if you keep it hooked up. i have never had the memory go away and i have it stored for several months now. you should top off the nmhi every thirty days so it will be ready when you need it.
K3CFC
Don't confuse my personality with my attitude.
My personality is who I am.
My attitude depends on who you are.
Old 02-25-2013, 4:57 AM
After reading your reply I have decided to keep my full battery pack disconnected from the actual radio and just rubber band them together. Hopefully this will last for a couple of months or more with little self discharge.
Old 02-25-2013, 2:57 PM
k3cfc's Avatar
I just read your post and sitting here right now i just put my battery pack on my t7h and it works as normal. i haven't had it together sense Sept last year.
Good luck and happy hammin.
K3CFC
Old 02-25-2013, 3:29 PM
robertmac's Avatar
Question EPROM
If EPROM memory should be retained for years despite depleted batteries. If have old computer can use software to program and it is a quick download even if memories are lost.
Old 02-27-2013, 2:19 AM
K3CFC, If your battery pack was empty or off since September then that is pretty much conclusive that the memory lasts 'forever" so I think I am pretty safe with my plan to keep the pack disconnected.
Robert, I am not sure of what you are saying.. As far as I know the ICT2H isnt programmable on a computer, just manually, but I am not a computer whiz....
Old 02-27-2013, 4:44 AM
k3cfc's Avatar
Google is your friend. RT Systems IC-T2 Radio Programming Software
