Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
Old 03-07-2013, 6:57 PM
Default Is this the ‘sweet spot’ on the S-meter bars (Yaesu FT-857D) ?
I’m new with Amateur Radio and the Yaesu FT-857D. I usually adjust the SQL/RF GAIN where it’s audibly comfortable for me. I notice on the S-Meter bars there is one wide bar (see image).
Is that what one might call a sweet spot? Just wondering what it’s for, if there is a particular reason.
73!
Old 03-08-2013, 12:16 AM
robertmac's Avatar
Exclamation RTFM
As all good up and coming hams do before operating a radio.
Old 03-08-2013, 12:40 AM
mancow's Avatar
It is the rlative RF gain level. It moves as you turn the knob right? Top is max and bottom is minimum.
Old 03-08-2013, 12:49 AM
OH, PA, WV Regional Admin
Your signal is s9+ and the place you are pointing to is s9.
Old 03-08-2013, 7:59 AM
WB4CS's Avatar
What do you mean by "Sweet Spot"?
Check the owners manual. If it doesn't mention anything about it, it could simply be a glitch in the display.
Brandon, WB4CS
Kenwood TM-V71A, TM-281A, TH-K20A. Yaesu FT-60R
Amateur radio is a hobby. We supplement emergency communications, not replace them.
Old 03-08-2013, 12:06 PM
Robertmac, I did read the manual. In fact I read a copy prior to it’s arrival vary thoroughly. But if you know anything about Yaesu operating manuals, you’ll know that they do not provide a whole lot of in-depth detail.
I was pleased to receive a private message here from someone that explained the bar on the meter. Turns out that he too was curious and contacted Yaesu. He was told that the bar in question is just a visual spot on the meter to set the gain at S9 as an average position.
73!
Old 03-08-2013, 1:51 PM
majoco's Avatar
Whaaat?
What happens if you go to a VHF/UHF band and switch to FM narrow - can you move the little spot up and down with the squelch control?
Don't forget that Yaesu write poor manuals with bits missing!
Old 03-08-2013, 10:35 PM
davedaver1's Avatar
Here's a public message to explain the meter. On page 56 of the manual, the procedure for setting mic gain in FM mode uses 16 bars on the meter. The little "tic" to the left is the 16th bar.
Get the PDF, do a find on what you're looking for!
A bunch of scanners
A bunch of ham radios
Old 03-13-2013, 4:00 PM
62Truck's Avatar
if you switch menu item 80 from "RF-GAIN" to "SQL" that will get rid of that and work a lot better.
Lions, Tigers, Bears....
Old 03-15-2013, 5:36 PM
davedaver1's Avatar
How is that supposed to help?
A bunch of scanners
Old 03-15-2013, 10:28 PM
62Truck's Avatar
It changes the squelch knob from RF-Gain knob to a squelch knob. By default it's set to RF-GAIN.
Old 03-16-2013, 12:43 PM
davedaver1's Avatar
The OP originally wanted to know what the 16th bar indicator on the meter was. Changing the knob's function to SQL puts the RF gain at max all the time. He was previously adjusting the gain to suit his listening. Now that won't be happening. There isn't a reason to change the function.
A bunch of scanners
Old 03-16-2013, 1:32 PM
62Truck's Avatar
I miss read the original post. I apologize. I was always under the assumption that the bar was mainly for ALC marking that you didn't want the ALC going above that point.
Old 03-16-2013, 10:13 PM
robertmac's Avatar
I'm still confused. The screen does not indicate FM transmission but USB on 7.185?
Old 03-16-2013, 10:29 PM
62Truck's Avatar
There is nothing that states that you can not use USB on on the Lower HF bands. Even though LSB is preferred, technically there is nothing wrong with it, if that was the case they would make the radios in such a way that you couldn't.
Old 03-21-2013, 12:59 AM
Meanwhile I answered this a while ago...the mark is S9 and we are viewing a signal that is S9+.
Old 03-21-2013, 8:20 AM
DaveNF2G's Avatar
So there are two "right answers" according to this thread.
1) The long bar indicates S9.
2) The long bar indicates an adjustment level.
So which is it really? Or does it depend on what mode the radio is operating?
David T. Stark
NF2G WQMY980 KYR7128
Old 03-22-2013, 12:44 PM
KD8TZC's Avatar
No, it means that the flux capacitor is exceeding its recommended duty cycle.
John
KD8TZC
