Amateur Radio Equipment For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
Old 11-08-2013, 8:18 PM
wesm1957's Avatar
Default Mirage B-23 30 watt amp question
I picked up a use B-23 amp and I have a question about transmitting with the amp not powered up. Am I able to transmit thru the amp without causing damage to the HT I am using. Also will it transmit with out power on 70cm?
Wes
Alinco DR-605T, Baofeng UV-5R, Baofeng UV-5RC, PRO-106, Bearcat 996T, Bearcat 101, Icom IC-PCR100 (2),
Old 11-09-2013, 6:33 AM
If there is no voltage going to the amp, you can transmit UHF through it no problem. It would be invisible to the radio, & antenna.
GARY N4KVE
Old 11-11-2013, 4:41 PM
The vast majority of amplifiers will allow current to flow through them when they're not turned on. I have a 2 meter amp in my truck and when I transmit on 70cm, the relays simply don't switch and the RF passes right through the amp no problem.
K9LTC - Landon
Old 11-12-2013, 12:33 AM
wesm1957's Avatar
Thanks for the info!!!! Soon I will be using the amp in my shack. I have a dual band mobile on the way.
Wes
