Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
Old 08-18-2014, 11:07 PM
VE3JSO's Avatar
Default question please help
i have a kenwood ts-450s and my alc meter don't work so when i adjust the power and mic gain car gain i am doing it blind i was wondering if there is a external alc meter that i can buy or if there is another way of doing it
jamie
- Jamie VE3JSO
Pro 90, Pro106, KENWOOD 450S, Tr-7800 yeasu ft-60r baofeng uv-82l,
http://www.starrsoft.com/software/win500/
Old 08-19-2014, 12:57 AM
For starters, I'd suggest setting your ALC at the one-third level and leave it there.
Otherwise, my understanding is that the 450S can be operated by software, for example HRD. Perhaps a software app shows the ALC level?
Shawn WB6JWB
Paso Robles, California
www.TheRadioRoom.org
Old 08-19-2014, 9:51 AM
Does the meter work for everything else? Just thinking that if it does then there may be something wrong with the alc circuit. Do you get ok signal reports?
BB
Old 08-19-2014, 12:13 PM
VE3JSO's Avatar
the s meter don't work but the swr meter power meter works fine when i am on the air the report i get back is between 55-20 over s9
- Jamie VE3JSO
Old 08-25-2014, 12:12 AM
VE3JSO's Avatar
on the kenwood ts-450s how do i set the alc it is the mic or pwr knobs?
- Jamie VE3JSO
Old 08-25-2014, 12:29 AM
Scroll down to post #5 of this thread; the adjustment method is described (which may also be the source of the issue with the meter).
TS-450S High ALC Reading
Shawn WB6JWB
