Hello,
I have a Kenwood TS 2000 purchased in 2004. It functions fine except for every once in a while it will resort to a factory reset when turning on the power supply. There seems to be no constant, sometimes going just a few minutes to several weeks.
As long as power is supplied, it will not lose its settings. In other words, I can turn the radio off and on just fine and never experience a random factory reset. But as soon as I cut power to the radio there's a chance it will do a factory reset.
Typically in such a case, you would replace a lithium battery. That's not the case with a TS 2000. It does have an internal battery, but that's limited to the TNC settings.
I figured maybe some kind of corruption was causing it to reset. Upgraded to the latest firmware with no relief.
Anyone else seen this behavior? Anything to try.
Thanks,
Chance KC5EOK
Thanks,
Chance KC5EOK
