since you have made a lot of assumptions through your undeveloped skills as a detective I will not cry foul. <snip>
I think I see where this is going. <snip>
Since the Yaesu FT-101e covers the CB frequencies and since you are possibly not up to getting your ham license and since you are actually using a CB antenna, was the whole intent of this purchase to be a very expensive CB base station? <snip>
Thank you for not crying foul.
Notice in my post I used limiting statements such as "I think..." and "...you are possibly..." and then a question "...was the whole intent..." so I did not say anything definitive. Your statements had a
LOT of circumstantial evidence that prompted me to ask you for clarification. And that you have now done. Thank you.
As far as becoming a ham and gaining a license this was the reason for my purchases. I have all winter to study and look forward to accomplishing my goal. <snip>
That is great. I built my entire Heathkit SB-102 tube transceiver before I had a ham license in 1974 so I could learn morse code. I also had a dummy load to transmit in to at no RF drive, i.e. no power output with Mic/CW gain turned to zero. If you need any help while studying for your license, by all means ask in the appropriate forum(s). I bet there are many hams here willing to be your Elmer (including me).
Sooooooo... If you want us to help you, you are going to have to stop looking for tubes (which may not be the problem) and answer our questions and work with us. The Yaesu instructions to tune the transmitter that I will use to coach you along is found at:
http://foxtango.org/ft101/graphics/Transmitter%20Tune%20UP.JPG
Now, before we get in to the actual tuning of the transmitter, you
MUST have the transmitter connected to a dummy load capable of
INTERMITTENTLY handling the transmitter's full output of 130 Watts. If you do not have an adequate dummy load, this one would be good to have.
Dummy load, 0-500MHz, 100W, dry
It only costs $26 and will be a must-have for helping you. With this dummy load, you will protect the finals (if they are still good) but you can only leave the transmitter keyed for 15 seconds and then leave it unkeyed for 45 seconds (25% duty cycle). If you can afford a larger dummy load that handles more power, that would be better. Bigger is better :lol: allowing you to transmit in to the dummy load for longer periods of time.
Gigaparts full line of dummy loads are found
here. They have 300 watt dummy loads for about $37. Just make sure you get either PL-259 or SO-239 connectors with the appropriate cable to connect to the FT-101e's RF output.
Once you tell me that you have a dummy load like the one shown above (or similar), I'll start walking you through the tuning instructions.
Is that a fair deal? Meanwhile, I'll try to find a pictorial of the FT-101e's front panel to refer to as we go through the tuning instructions. If you have Skype, I am also willing to go through the instructions in real-time so I can see/hear the results after each step.
Let me know if this sounds like a plan.
Finally, it would be "really nice" if you would read through our postings thus far and respond to our questions and comments. That will help all of us better understand your situation. For example, can the seller of the rig show you that it in-fact is a working rig or is that not possible and if so, why?
Looking forward to helping you with your FT-101e and also helping you get your ham license.
73, Dave K4EET
