Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
Old 05-19-2017, 7:50 PM
3me 3me is offline
Default Kenwood TM-V7 Reset
Unfortunately, my Kenwood TM-V7 seems to have lost its mind. Some of the programming does not work following the manual and other features disappear each time the power button is turned off. I am afraid it is time for a HARD RESET and to nuke the memory. The only reset I could find listed in the manual was to erase the memory channels, but that did not resolve the issues. I would like to reset it completely back to factory condition and start anew. Does anyone know what combination of buttons will accomplish this?
de WAKS
Shawnee, KS
Old 05-19-2017, 8:41 PM
W9BU's Avatar
Lead Wiki Manager
The manual mentions a button hidden by the display that will do a full reset. See the Maintenance section of the manual.
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
Old 05-20-2017, 7:48 PM
cmdrwill's Avatar
If it is an older ' V7 ' it may have a button size memory battery. Those go dead over the years. It may be soldered i no one of the boards. May be on the control head circuit board.
Old 05-21-2017, 3:53 PM
Remove the face, and on the panel, slightly to the leftt, you will find a small hole that contains the switch. Use a non-sharp tool of appropriate size to press that butoon in, AND hold for more than 1 second. That is the "Hardware re-set" procedure.
