Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
Old 06-13-2018, 9:44 AM
Smile Yaesu FT-60 Programming
Hi- I have two questions for the group.
Iím a relatively new ham and have a question about programming my Yaesu radio. Iím a volunteer with the National Park Service.
We patrol the parks using a FRS channel to communicate between ourselves. We patrol on mountain bikes and keep the radios are in our back packs. We need to monitor the park repeaters for status checks. I have the frequencies stored in memory bank 1 of the radio and I can get the radio to scan all frequencies. Is there a way to have the radio scan all frequencies Ė but have the radio default transmit to a home frequency? In order words Ė unless I need to respond to a park service call Ė Iíd like the radio to transmit on the FRS channelÖ
Question 2. One of our park repeaters uses an offset of 8.3625. I can only get me radio programmed to 8.35. This seems enough of a difference to where I can't get the repeater to respond...
I appreciate any help
KK6SRB
Old 06-13-2018, 10:31 AM
Will001's Avatar
Someone correct me if Iím wrong, but I donít think the FT-60 (a ham radio) is meant to transmit on federal and FRS frequencies. It has to be approved by the FCC for it to be fully legal.
HAM Radio Call: KN4IMX
GMRS Call: WQYT-477
I own too many radios to put in the signature
ō=a bad day for scanner enthusiasts, and also a bad day for public safety...
Old 06-13-2018, 10:35 AM
Citywide173's Avatar
I can say with 100% surety that the radio is not type accepted for FRS simply because of the power limitations and the fact that the antenna is detachable.
As far as the NPS frequency goes, I'm pretty sure it falls under NTIA, so I don't think FCC type acceptance applies, but I would assume there's an equivalent that applies.
Ed Burke
KD1EMS WQRD823
Administrator: Firepics-THE Place for fire photographers
Old 06-13-2018, 10:36 AM
Default Yaesu 60
Hi-
We transmit on low power when using FRS.
Old 06-13-2018, 10:39 AM
Will001's Avatar
I understand that. The problem lies with the antenna. The FCC is very clear about any FRS radio having a fixed antenna. A removable antenna on a radio transmitting on FRS frequencies is illegal.
GMRS Call: WQYT-477
Old 06-13-2018, 10:42 AM
Will001's Avatar
I also just checked an online list of NTIA accepted radios, and the Yaesu FT-60 was listed as NOT NTIA acceptable.
GMRS Call: WQYT-477
Old 06-13-2018, 10:43 AM
I didn't know that. There are many members that use Baofeng radios... I happen to have a Yaesu. Looks like I'll have to go shopping for an FRS radio. Any ideas as to the offset?
Old 06-13-2018, 10:47 AM
Will001's Avatar
I think the offset doesnít work right on the radio because, like I said, it was not made to transmit on Federal frequencies.
P.S.-The other people that you work with that are using Baofengís are running the risk of getting caught by the FCC. While it is a small chance anyone would actually catch them, it still is a risk.
GMRS Call: WQYT-477
Old 06-13-2018, 10:51 AM
Hi -
Not the answer I wanted to hear... but I thank you for the education and the quick response.
Old 06-13-2018, 7:30 PM
I believe Baofeng low power is 1 watt, which means that they are transmitting at twice the legal power in addition to the removable antenna
Ed Burke
KD1EMS WQRD823
Old 06-14-2018, 9:27 AM
Default Thank you for the education
I'm going to have a talk with the other volunteers...
