Amateur Radio Equipment - For general and technical discussion of Amateur Radio equipment such as transceivers, repeaters, controllers and receivers.
Old 09-14-2018, 7:58 AM
Default Lowest power setting for FT-817ND
Hey,
what's the lowest power output FT-817ND is capable of after tuning up HF1,2,3-L1 in service menu?
Tnx
Old 09-14-2018, 8:37 AM
Originally Posted by andrew30 View Post
Hey,
Tnx
I had to lookup the service menu, but I assume you are referring to menu items 27, 31, and 35. The description I see for each is:
HF1-L1: This sets the RF output power in the L1 power setting for HF Band 1 (0.5 watts.)
HF2-L1: Same as HF1-L1 except for HF Band 2.
HF3-L1: Same as HF1-L1 except for HF Band 3.
The default for these is 0.5 (i.e. 0.5 watts) Whatever you set in these settings will be the wattage when you select the L1 power setting.
Old 09-14-2018, 8:44 AM
Sure, but how low can you take the settings? 0.05W, 0.001W?
I don't have 817ND here to test.
