Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General Discussion Forum for Amateur / Ham Radio Topics
Old 07-12-2009, 03:57 PM
CLynch7's Avatar
Default Echolink link on calling freq?
I've been thinking about setting up an echolink simplex link. I've got a Motorola Radius SM50 (I think it works) and a spare old desktop. If I get it all set up, I was thinking about putting it on 446.0. There doesn't seem to be a whole lot of 70cm activity around here, just on the repeaters. Any ideas?
Chris, KJ4MPT
Radio Shack Pro-51, Pro-75, Pro-83
Grundig G5, G6 Aviator, TRII Digital
GE 7-2990A, Kenwood TH-78a Dual Band
Old 07-12-2009, 04:07 PM
It is not a good idea to run links on calling frequencies like 446.0 or 146.52.
You should find out if your state or regional frequency coordinator has band plans for where they recommend running VoIP links.
Tom
Old 07-12-2009, 04:24 PM
I second that motion!
Old 07-12-2009, 04:25 PM
newsphotog's Avatar
I know that when I travel I like to stay tuned to 146.52 when I'm out on rural highways. I like to make local simplex contacts that way. I haven't used 446.0 but I think I would be less-than-enthused to find out I wasn't making a local simplex contact, rather just a contact over Echolink. For me it would not be as useful or practical if I wanted to use it for local information.
Old 07-12-2009, 04:31 PM
Send a message via AIM to fineshot1
There are plenty of other simplex freqs on 440 other than the 446.000 national simplex calling freq.
Contact SERA (your areas coordinating org) and look up the band plan for 440 and you should be
able to find a few that are available.
fineshot1
NJ USA
Old 07-12-2009, 09:38 PM
Technically, it isn't against FCC regs., but it could prove to be inconvenient to others in your area who want to use 446.0.
Old 07-12-2009, 11:31 PM
CLynch7's Avatar
Good points on 446.0. SERA said any simplex would be fine. It'll be a while before I'd have it up, so I'll have a chance to make sure other freqs aren't used for nets or Skywarn. May not happen at all, I'm not 100% on if the radio still works.
Chris, KJ4MPT
Old 07-20-2009, 12:52 AM
burner50's Avatar
Bob Loblaw
Send a message via AIM to burner50 Send a message via MSN to burner50
I debated putting mine on 146.52... Do a search for .52 in echolink and you will come up with surprising information... That situation was rectified when i was asked to put it on an EMA repeater pair, and given a tone board to facilitate the move.
I know somebody who was trying to get an SM50 as a link radio. For some reason the audio in connector on the accy plug on that radio was very low audio... Last I heard, he was looking for an amplified sound card for his computer... FYI
Jason
Moderator / Iowa Database Administrator
burner50@radioreference.com
Rules and guidelines for forum post content
Old 07-22-2009, 10:37 PM
CLynch7's Avatar
I've looked, seem there are some that are on the calling freq. Mine won't be.
Thanks for the heads-up on the low audio. I've got a preamp somewhere, or at worst, a mixing board. Hmm, a board would allow for something to play the ID, hmm....
Chris, KJ4MPT
Old 08-23-2009, 04:28 PM
jwilkers's Avatar
Not good putting a link up on a call freq. Heard a big stink about someone who did it on 146.52... pretty much all the die hard Echolink folks were wanting to find the guy and tell him to knock it off.
Don't clutter the call freqs... not polite to set up a ragchew system on a call freq.
John
Amateur: KD8DVR
GMRS: Expired.. use TriSquare eXRS now.
Old 08-24-2009, 02:22 PM
Default Busy
I have to agree with the above. It's annoying having to wait for a break just long enough for a quick call.
APTN
Old 08-24-2009, 06:33 PM
CLynch7's Avatar
I'm still not sure if the radio works or not. The PC I'd be using needs a new HD, so the project is now very low on the list. I'm not even sure if I'll be in the same location in a months time.
Chris, KJ4MPT
Old 08-24-2009, 07:08 PM
SlipNutz15's Avatar
Send a message via ICQ to SlipNutz15 Send a message via AIM to SlipNutz15 Send a message via MSN to SlipNutz15 Send a message via Yahoo to SlipNutz15
Well, either way, good luck with your project. IF you decide to do it, don't do it half asked. You wouldn't want someone else doing a project half asked so do the best you can and if you need to save up for a few months before you get it online, do that. I'm thinking about doing the same thing but it's going to take some time.
Gregory J. Stottle KB3THR
http://www.centralpascanner.com
Old 08-30-2009, 05:27 PM
CLynch7's Avatar
Thanks! I'm hoping to get it up and running sooner rather than later. I've been looking at using the computer power supply to run the radio. The power for the 2nd HD is 12v and I'm pretty sure 20a. I'm also looking at j-pole plans, probably build one from stainless and aluminum. Just seeing if it'll all work together is going to be half the fun. Good luck on yours too whenever you start.
Chris, KJ4MPT
Old 09-01-2009, 05:29 AM
Chris,
If you decide to use the PC's power supply here are a couple links that may help:
Switching Power Supplies: Resurrect that Old Junker PC Supply!
Power Supply : Technical Reference: Power Supply
Greg/KD8JUV
I'm not worried about the bogeyman, I'm worried about the man with nothing to lose.
Old 09-01-2009, 09:05 AM
My idea would be to use the calling frequencies exactly the way they were meant to be used.....as calling frequencies. If you do a search, you will find a list of other 70cm simplex frequencies that you can use instead. I wish you the best of luck with your project but also please remember that we need to also be considerate of our fellow operators as well.
Similar Threads
Sticky Thread For MilAir IV TinEar Maryland Radio Discussion Forum 5137 Today 04:24 PM
Ambulances on Police Freqs zerg901 Massachusetts Radio Discussion Forum 34 09-14-2009 05:34 PM
Sticky Thread for MilAir II TinEar Maryland Radio Discussion Forum 4098 01-01-2008 11:21 AM
Sticky Thread for MilAir TinEar Maryland Radio Discussion Forum 2734 11-10-2006 06:51 AM
MPT system in Mohegan Sun Casino Unitrunker Connecticut Radio Discussion Forum 11 07-09-2006 10:11 PM
