Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General Discussion Forum for Amateur / Ham Radio Topics
Old 07-18-2009, 04:50 PM
Question 2 meter help!
I have 2 yaesu radios a vx-5 and ft-60 and when using them they only work about 100 feet apart. I dont know if I have a setting wrong or what but does anyone know how to fix this problem or what to do? any help is appreciated Thanx.
Old 07-18-2009, 11:39 PM
gewecke's Avatar
Post
Well,make sure your antenna is secure first of all. I'm assuming you're on the same frequency on both radios as well,right?
N9ZAS.
Old 07-18-2009, 11:49 PM
All CTSS codes match/disabled?
Old 07-19-2009, 10:24 AM
Sometimes when you are TOO close, one will overdrive the front end of the other. Be sure you are using the lowest power possible if that close.
Kevin
KD8IIB
GRE PSR-500
Yaesu FT-60R
Yaesu FT-8900R
Alinco DR-610T
Yeasu FT-50R (2)
Old 07-19-2009, 10:43 AM
burner50's Avatar
Bob Loblaw
Send a message via AIM to burner50 Send a message via MSN to burner50
If you're talking on a repeater, then you're not using the same frequency, but 1 is 600kHz away, this overloads the receiver of the other one and drowns out the transmitted audio of the repeater.
If you're using the same simplex frequency on both, then this should not be an issue.
Jason
Moderator / Iowa Database Administrator
burner50@radioreference.com
Rules and guidelines for forum post content
Old 07-22-2009, 09:04 PM
Default still not working
im transmitting on the same frequency no repeater both are set to regular squelch no tone or dtmf code and the antenna is tight the only thing is the vx-5 is running off of a car adapter I think they should have ample power I'm just getting baffled
Old 07-22-2009, 09:50 PM
Fast1eddie's Avatar
Ok, you are operating simplex. The above posts are correct, you are overloading the receiver.
Edward Hutton
Old 08-01-2009, 01:10 AM
K2QI's Avatar
What's your call sign?
73 de James K2QI
Old 08-02-2009, 01:15 PM
Are you licensed? If you passed your Tech test you should know that you are operating simplex.
Old 08-02-2009, 02:47 PM
What does that have to do with two radios that don't talk to each other?
prcguy
Old 08-02-2009, 07:10 PM
N1BHH's Avatar
Send a message via AIM to N1BHH Send a message via MSN to N1BHH Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
You may need to look at the display while transmitting. This may indicate what frequency you are actually transmitting on. You may be trying to operate in one of the repeater subbands and both radios are equipped with automatic repeater shift. You should know what the repeater subbands are and what section of the band where simplex is the norm. I think you may actually be in a repeater subband, otherwise you would hear one or the other radio with no desensitization. Don't think you are overloading anything. These radios are well designed with plenty of filtering from adjacent frequency stuff. Have you tried this with someone else in your area? What frequency are you trying to operate on?
WQBX787 = GMRS
Pro2055 Pro94A Pro2006 Pro2015 Pro2021 Pro164
Yaesu FT-60R, 8000R & 8800R, Motorola MTX9250, Alinco DR635T
Old 08-02-2009, 09:37 PM
k8mcn's Avatar
Send a message via AIM to k8mcn
prcguy
PRETTY SIMPLE if he isnt licensed we shouldnt be helping him transmit on 2 meters,and if he is, he gives his call, we help him all we can and all is good..............
Many of life's failures are people who did not realize how close they were to success when they gave up.
Thomas A. Edison
Old 08-02-2009, 10:08 PM
kb2vxa's Avatar
When one transmitter can only reach 100' at best the answer is simple, a blown FPA module. When TWO transmitters exhibit the same symptom odds are the difficulty lies with the operator. When the difficulty lies with the operator he shouldn't be on the air since he doesn't know how to operate his own equipment... simple enough? Draw your own conclusions.
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Old 08-02-2009, 11:33 PM
Once again a new member gets attacked after asking a question.
Old 08-03-2009, 12:36 PM
I dunno, Warren makes a good point, anyone playing around transmitting on 2m really should have more of a clue as to what they're doing than the OP seems to have.
Lots of radios, not enough antennas...
Old 08-03-2009, 01:39 PM
Nothing in their posts tells me that they are not a licensed operator. It doesn't say they are either, but with replies like some of these who whould want to give their call sign. This person may not have access to rr on a daily basis and before they could reply with their call sign people were already jumping all over them.
Danb8220,
If you have the EDC-6 or the EDC-5B the radio will not transmit using the power supplied by the cable. If it transmits at all while plugged up it is using power from the battery not the cable. The VX-5 may have a bad battery or is not charged enough which will definately cut your tx power. I don't know of a DC adapter that will power that radio while you transmit. There may be one, but the two above are just chargers.
Old 08-03-2009, 01:44 PM
I agree with N1BHH. It sounds like you are trying to operate in a repeater sub-band. While it is common courtesy to use a standard simplex frequency for simplex communications, this could also be a learning tool for you in the event a repeater would go down during an emergency. Look up how to turn off your repeater shift so that you are transmitting simplex on the output. Once you can hear each other that way, then switch over to a regular simplex frequency to carry on your conversation. Also make sure you are not interrupting someone's conversation during your brief test. It's considered bad etiquette to talk simplex on an output frequency for an extended period unless the situation warrants it.
Last edited by dwh367; 08-03-2009 at 02:19 PM.. Reason: Huked on fonics wurked fur me
Old 08-03-2009, 02:43 PM
Or he goes on QRZ and bootlegs one and gives it to you and no one can verify it is indeed him so whats the point?
Old 08-03-2009, 02:47 PM
Well if no one is willing to elmer him then chances are he won't be on the air. The guy is asking for help. So we just say he doesn't need to be on the air because he doesn't know how to operate it. Hes trying to learn how to operate it by asking here. No wonder new folks say us old hams are mean.
Old 08-03-2009, 05:25 PM
K2QI's Avatar
Amazing. So much fuss over asking about a call sign. If the guy is licensed, then it shouldn't be a big deal to tell us.
I'm sorry, but I'm not about to go and help anyone out there just because they have a radio. We have enough lids and jammers as it is... and I'm certainly not risking my license to help someone who may possibly wish to engage in illegal activity.
Anyway, I'm not saying this guy isn't legit. I don't have enough information to make that conclusion.
My request for a call sign was not a personal attack. For those who think it was, wow.. just wow.
73 de James K2QI
Similar Threads
FS: RadioShack CB/HF Ham Power/SWR Meter chrismoll Old Classifieds Archives 5 08-31-2008 11:59 PM
vr-120 Step Size redmonds All Other Receivers 2 08-29-2007 06:44 AM
FS- Misc. Stuff, Antennae, Meter, Shortwave, Etc. KG4LJF Old Classifieds Archives 10 08-01-2007 08:16 PM
galaxy 2517 10 meter policeMonitor Old Classifieds Archives 2 04-08-2007 07:09 PM
20, 30 or 40 meter - CW Pro-95 Tavern Archives 18 06-30-2005 01:01 PM
