Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General Discussion Forum for Amateur / Ham Radio Topics
Old 07-25-2009, 03:14 PM
Send a message via MSN to kd0ezq Send a message via Yahoo to kd0ezq
Default Radioshack cable and Icom 208H...HELP!
Guys,
I have an Icom IC-208H and I have my Radioshack 20-047 cable..I have read that they can be used together with the cs208 software to program the radio.
I have tried using the stereo and mono plugs and cannot get the radio to read...I have set the com port to 9, which is what shows up under device manager on my computer which is running XP.
Any ideas what Im doing wrong?
Tim
KD0EZQ
Old 07-25-2009, 05:21 PM
burner50's Avatar
Bob Loblaw
Send a message via AIM to burner50 Send a message via MSN to burner50
Originally Posted by kd0ezq View Post
Guys,
Tim
KD0EZQ
I've never heard that before, and cannot find any supporting information on the internet, But I am eagerly awaiting the answer...
Jason
Moderator / Iowa Database Administrator
burner50@radioreference.com
Rules and guidelines for forum post content
Old 07-25-2009, 05:24 PM
Send a message via AIM to fineshot1
Guys,
Tim
KD0EZQ
Never heard that one about the RS cable.
As far as I know you need either the icom opc-478 or the alinco erw-4c cables to get it to work.
fineshot1
NJ USA
Old 07-25-2009, 09:53 PM
N8IAA's Avatar
The older DB9 serial cable that is used to program Icoms/Yaesus, paired with a stereo to mono 1/8" adapter can be used to program the older RS scanners. Not the reverse.
Larry
Pro-106, Pro-163, Pro-99, FT-60R
Old 07-25-2009, 11:32 PM
There was a writeup in the October 2008 QST magazine by WB2GYK about it...I cant find any more information about it...
Im thinking it should work...since it is a usb to ttl interface...just like the OPC-478U cable...
Tim
Old 07-26-2009, 12:52 AM
burner50's Avatar
Bob Loblaw
Tim
I did find an article in the archive... But the crooks at ARRL dont have it online so you can download it, you have to buy the periodicals in CD form
Another reason I LOATHE the ARRL...
I dont have that issue... They generally go from the mailbox to the trash.
Jason
Old 07-26-2009, 01:10 AM
w8jjr's Avatar
Send a message via AIM to w8jjr
If I remember correctly you have to use three ring plug and build a null modem pigtail to reverse tx and rx.
Jim
W8JJR
Old 07-26-2009, 07:39 AM
n5usr's Avatar
And here I was thinking those stacks of old QST magazines were wasting space...
The article you mention is for connecting to an IC-7000, so I don't know that it will work with the 208H.
It doesn't mention needing a different wiring, just says he uses the stereo-to-mono converter supplied with the interface.
The interface settings used in the HRD software were:
COM Port = Auto-detect, Speed = 19200, CI-V Add = 70, DTR = not checked, RTS = not checked
Not sure if that helps any...
Edit: The author also says he first found out about this on the IC-7000 Yahoo group.
Old 07-26-2009, 12:49 PM
Note that the IC-208H uses a different cable than the IC-7000 uses.
Since the 20-047 cable apparently uses the tip of its TRS plug for both TX and RX signals and the Icom IC-208H uses the ring section for both TX and RX signals, I would think that a fabricated cable adapter pigtail to be used with the 20-047 would have a TRS jack on one end and a TRS plug on the other end. The sleeve sections would be connected together and the tip section of the jack would be connected to the ring section of the plug.
Old 08-07-2009, 09:32 AM
Get the cable from RT Systems.
Similar Threads
FS: ICOM 208H w/ extras pcfn360 Old Classifieds Archives 0 12-09-2008 08:41 PM
FS: Icom Cloning Cable and Software Twister234 Old Classifieds Archives 3 01-06-2008 05:37 PM
Icom 208H Separation Cable WatnNY Old Classifieds Archives 0 07-15-2007 06:46 AM
Icom 208H Separation Cable WatnNY ICOM Receivers 0 07-08-2007 01:24 AM
Icom 208H Separation Cable WatnNY Old Classifieds Archives 1 07-07-2007 11:53 PM
