On the HTs (VX6 or VX8) Yaesu does not have delete memory function. You can hide the location or over-write it.
So... if you are like me and like to keep things ordered and by the numbers then the programing software is the best choice.
The application on the PC uses the cloning function of the radio. So every time you write to the radio it is a complete update of the radio memory based on the current data in the application and how it is organized.
Originally Posted by morte
which way would be easy on me
should i do it manually or should i get programming software
how hard is it to program a yaesu radio
