Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General Discussion Forum for Amateur / Ham Radio Topics
Old 08-23-2009, 01:45 PM
chief21's Avatar
Default multi-band vertical - 10m + 6m???
Is anyone aware of any multi-band vertical antennas primarily for 6 and 10 meters? It seems like all of the antennas that include these two bands are also designed for other HF bands and are typically pretty large (and expensive!). I'd like to find something mainly for 6 and 10.
Thanks in advance for any assistance.
Old 08-23-2009, 01:48 PM
gewecke's Avatar
Wink
Check with these people!
AES Home page
They have a broad selection of antennas available.
N9ZAS
Old 08-25-2009, 01:08 AM
The only 10/6 meter antenna I've ever seen that wasn't home built was a mobile antenna designed with the Syntor X in mind. I don't know that it's still available.
A vertical for those two bands would be pretty easy to build, though. Probably far cheaper than you could buy.
12 volt radios are for wimps. Real radios can kill you.
Old 08-25-2009, 10:24 PM
k9rzz's Avatar
It's probably tough to get both bands on one antenna, but you could try.
Get a CB ground plane and modify that (shorten it) for 10 meters. A 2 meter 5/8 whip will work on 6m.
Old 08-26-2009, 01:21 AM
Technically, it would be rather easy. The problem would be that there isn't much demand for it - not just those two bands. This is where home brewing comes in.
Old 08-26-2009, 10:25 PM
A home brew 10/6 fan dipole is cheap and easy and takes up very little room at half wave.
K C 2 P B J
Other useless license information.
List of my out-of-date radios.
Other data that nobody cares about.
Old 08-30-2009, 08:58 PM
chief21's Avatar
Thanks for all of the suggestions thus far. However, let me reiterate... I'm looking for a combined VERTICAL antenna for 6 and 10m.
I already have a long random wire in the air for horizontal SSB but I need something for 6 and 10 vertical FM. All of the multi-band verticals that I've seen in catalogs are 1) way too tall and 2) very expensive!
A solution that could be configured the about the same as a nominal 15-20' tall vertical antenna would be ideal, since I need to keep the antennas/wires as unobtrusive as possible.
Thanks again for your thoughts and ideas.
Old 08-30-2009, 10:49 PM
Another way to do a 10m/6m vertical, is to make a 10m vertical out of aluminum, or whatever. Then, you make standoffs about 3 inches long. You attach the standoffs to the 10m vertical, and space them every couple feet. You should have already put a hole at the far end of the standoff. You just run a 1/4 wavelength long wire for 6m up the side of the 10m vertical. You also need to use at least 3 radials for each band.
My favorite material to use for the standoffs is Plexiglas. I attach the standoff using a small U-bolt.
It really depends on what kind of operation that you need the antenna for. If you are going to be doing local FM on 6m, then this antenna would work great. If you want to do Es on 10m and 6m it will do so-so. In my opinion, the 6m/10 inverted V will be the best compromise for doing it all on both bands.
John, AD7VH, east central Nevada
Old 09-13-2009, 07:55 PM
The antenna known as the "A99" and sold under the brand of Solarcon or Antron works well on 10 meters, and I have been told it will tune to 6 as well. I have not tried it, though. It is an 18', 3 section vertical.
73
Edit: OK. I tried it. I disconnected my 6m vertical and hooked up the A99. I lost 2db of reception of a local repeater and was only able to tune SWR down to 3.0. I think not (but hey, it was an experiment)
Old 09-13-2009, 09:16 PM
With the Antron 99 being a fullwave on 6m, this would present some problems. One, it would have a very high impedance on 6m. Another fact, it would also put most of it's radiation up at around 30 degrees. Once you get longer than 5/8ths wave the pattern starts to go higher, not lower.
If you want a dedicated dual band vertical for 10m and 6m. I don't know if you want another antenna for just 6m, or to have one antenna and one feed-line. If you want one antenna and one feed-line, you can do like I suggested before. That is, you just make parallel antennas. You make the 10m vertical out of some kind of tubing; you make the 6m part out of wire; run it alongside the 10m vertical, and space it about 3" from it using insulators. You also need to make 3-4 radials for both bands. These, too, can be ran parallel to each other. For the radials, I suggest using 300 ohm ribbon wire: you just cut 3-4 radials for 10m, and then cut one side of the ribbon wire for 6m. When you cut it for 6m you just need to make a 1" gap in the ribbon wire on that side.
I hope that helps.
73, John, AD7VH, east central Nevada
Old 10-15-2009, 09:14 PM
chief21's Avatar
Default I think I may have found one...
First, let me thank everyone who has offered antenna suggestions thus far. Good ideas!
Today I think I may have found an antenna that will meet my needs. The S9 jr antenna reportedly works on 20m though 6 m and is only 17' high, and it costs only $49. However, there is only one (1) review for this particular model on eham.
Can anyone here comment on the adequacy of the S9 jr antennas??
Once again, Thanks in advance for any input.
Similar Threads
FS: FS/FT: Motorola Maratrac 110w on 6m kd0ezq Old Classifieds Archives 1 02-18-2009 01:04 AM
Multi Quoted Messages btritch System-wide Administration 2 08-05-2008 05:50 PM
National Weather Service on 6m eorange Ohio Radio Discussion Forum 4 06-12-2008 12:50 AM
CSP Multi Site Links dimab Connecticut Radio Discussion Forum 7 06-07-2006 01:41 PM
Multi band antenna question nyscan00 General Scanning Forum 21 08-21-2004 04:58 PM
