Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General Discussion Forum for Amateur / Ham Radio Topics
Old 08-27-2009, 06:58 PM
Default VX8R narrow band reception
Trying to program some narrow banded forestry channels into my 8. it will not take them. keeps giving me an error message. the radio has been modified. any suggestions?
Old 08-28-2009, 10:56 AM
K2QI's Avatar
Are you trying to transmit or just receive?
What's your call sign?
73 de James K2QI
Old 08-28-2009, 06:10 PM
Default narrowband reception
Both. the radio will not allow me to even enter the frequency's. it will not take them.
Old 08-29-2009, 08:49 AM
K2QI's Avatar
What are the frequencies? What is your call sign?
73 de James K2QI
Old 08-29-2009, 11:58 AM
Check if menu # 96 Step Frequency is set to 6.25 kHz.
Old 08-29-2009, 06:48 PM
stateboy's Avatar
1.) 12.5 KHz or 6.25 KHz spacing? VHF or UHF?
2.) Why are you trying to use a hammy transceiver on non-amateur freqs? It's not type-accepted for use outside the hammy bands.
If your not a ham, sell the VX-8 and get a type-accepted narrowband-capable radio, which will likely be cheaper than what you spent for the VX-8. If you are a ham, then you should know better.
South Dakota: The most scanner-phobic gestapo state in the union
Old 08-29-2009, 08:19 PM
N1BHH's Avatar
Send a message via AIM to N1BHH Send a message via MSN to N1BHH Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
If you are trying to input receive frequencies which are not of the same channel spacing of the amateur radio bands, you won't be able to get the exact frequency, only the next closest frequency by default. The new VHF frequencies which many call narrow band are actually more correctly used via narrower deviation, 2.5 kilohertz as opposed to 5 kilohertz.
Since you are getting ERROR, that must mean you are trying to transmit out of band, which is not recommended. I suggest you not try to transmit with non type accepted radio gear as the FCC Part 97 radio is not acceptable on Part 90 or any other frequencies. If you are authorized to utilize these Part 90 frequencies, purchase an appropriate radio and do it properly.
WQBX787 = GMRS
Pro2055 Pro94A Pro2006 Pro2015 Pro2021 Pro164
Yaesu FT-60R, 8000R & 8800R, Motorola MTX9250, Alinco DR635T
Old 08-29-2009, 09:56 PM
eorange's Avatar
I have the VX-8R. I doubt he's seeing ERROR on the display, because you only see that when you transmit out of band. But the OP said he can't even enter the frequencies, per "the radio will not allow me to even enter the frequency's. it will not take them."
kf8yk is correct - you need to check menu #96. By default it's AUTO. Change to 6.25 kHz and the VX-8R will allow you to program narrowband frequencies. I just did this and it took 151.6275. Of course my VX-8R is still stock so I can't transmit there, just receive.
KA3FYU
Old 08-31-2009, 05:09 PM
Default vx8r narrowband reception
The frequency is 151.1825. my call sign is kg4hih. I am a firefighter and i like to be able to listen when i am off duty and only carry one radio. I did list my problem wrong in my original post. I do not get an error message trying to enter the frequency the radio just will not take the frequency. the step is set to 6.25.
Old 08-31-2009, 09:11 PM
Send a message via AIM to fineshot1
The new narrow band step for vhf is NOT 6.25khz. It is a 7.5khz step.
The new 6.25khz step is for uhf and NOT vhf.
Most of the rice box amateur equipment seems to ignore this fact and was not designed into it.
fineshot1
NJ USA
Old 08-31-2009, 10:18 PM
eorange's Avatar
Ah...sorry, this is not possible. The reason is the VX-8R's smallest step size is 5 kHz. But you would need a step size of 2.5 kHz (or, 0.5 kHz which is more likely) to enter the above frequency.
Enter a frequency of 151.180, and set #96 to 5 kHz. Then click the dial once; you'll jump right up to 151.185.
Hope this helps.
KA3FYU
Old 09-01-2009, 10:12 AM
eorange's Avatar
Default But do this...
I just looked up 151.1825 in the Florida database:
Scanner Frequencies and Radio Frequency Reference
That's an input frequency to repeaters. In general, you'll have better luck listening to the OUTPUT frequencies (even if you had a HT that could accept 151.1825).
Try one (or both) of the output frequencies, which the VX-8R will handle, and you'll be all set.
KA3FYU
Old 09-04-2009, 02:35 PM
Thanks for all of the input. Does not look like I will be able to get this freq. into the 8. I have seen the channel plan and this frequency IS listed as an input. I dont know exactly what they are using it for in my area but a couple of the DOF units in my area are using this as a simplex frequency to talk unit to unit? I will try the 5khz step and see if I can still hear them. Otherwise I will just have to monitor this one with a scanner.
Similar Threads
Bitterroot National Forest Radio Frequencies Helitac Montana Radio Discussion Forum 3 08-24-2009 03:03 AM
USCG freqs hntsgt Marine Monitoring Forum 9 01-01-2009 11:09 AM
New Guy Here! ADDam General Scanning Forum 8 10-11-2008 09:54 PM
Narrow Band ???? kc0rnp Illinois Radio Discussion Forum 3 01-21-2008 06:47 PM
Narrow Band Question lifeteammedic Scanner Programming Software 2 08-25-2007 03:07 PM
