Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General Discussion Forum for Amateur / Ham Radio Topics
Old 09-05-2009, 09:53 PM
Question amp
Hey folks kinda of a dumb question??? I just bought a amplifer on of flea-bay and I have no clue as to what freq. it will operate on. Is there any way of looking at the internal components to figure this out?????
Old 09-05-2009, 10:29 PM
k9rzz's Avatar
The auction didn't say?
You gotta give us more than that if you want help. Homebrew? Tube or solid state? Commercial? What manufacturer? Does it go in a car, sit on a table, or do you need to knock out a wall to get it in the basement?
Old 09-05-2009, 11:39 PM
N1BHH's Avatar
Send a message via AIM to N1BHH Send a message via MSN to N1BHH Send a message via Yahoo to N1BHH Send a message via Skype™ to N1BHH
The question I have for you is why did you buy something you know nothing about in the first place? You could very easily be stuck with a brick. Always look it over before buying. Now I think this is a dumb question.
WQBX787 = GMRS
Pro2055 Pro94A Pro2006 Pro2015 Pro2021 Pro164
Yaesu FT-60R, 8000R & 8800R, Motorola MTX9250, Alinco DR635T
Old 09-06-2009, 01:21 AM
gewecke's Avatar
Wink
Is it of cathode tube vintage or is it solid state? If it's a tube design then what are the numbers/letters on the tubes? Maybe describe the controls on the front panel? There are many ways to determine what you have!
N9ZAS
Old 09-06-2009, 08:24 AM
Exclamation
It is a mobile amp, no other manufactuer labels, the buttons on the front are power, low med hi, pre-amp. The auction did not say but for a 27.00 dollar gamble I will take it.
Old 09-06-2009, 11:35 AM
gewecke's Avatar
Wink
Maybe take the cover off and tell us what numbers are on the output transistors? That would give us some idea what band it's in.
N9ZAS
Old 09-06-2009, 11:43 AM
2 transistors that are sd1446 11c
Old 09-06-2009, 01:19 PM
Send a message via AIM to KS4VT
If there are tags on the unit you can go on the FCC website and look up the type acceptance number.
Old 09-06-2009, 01:29 PM
http://www.datasheetcatalog.org/data...cs/mXrxuvr.pdf
Probably some type of HF power amplifier.
No labels? Preamp? Low med high?
I'm reaching here, but my best guess would be a CB type amp.
12 volt radios are for wimps. Real radios can kill you.
Old 09-06-2009, 05:17 PM
k9rzz's Avatar
Let me approach this from a different angle ... what frequency range do you hope it works on?
Old 09-06-2009, 09:46 PM
i am hoping that it will cover 2 meters
Old 09-06-2009, 10:33 PM
The transistors that you told us were in it are only rated up to 50 MHz, therefor it's not going to work at 2 meters.
Old 09-07-2009, 07:03 PM
kb2vxa's Avatar
Rest assured it's a "2 pill" chicken band amp, solid state ham amps use MOSFET modules and their appearance makes them pretty obvious. If it hasn't any tuned circuits but rather as my guess input and output toroids likely it's a push-pull wide band amp that if you're lucky covers basically 3-30MHz it MAY be used to boost the power of a QRP rig or transceiver lowered to 5W, any more will blow it to kingdom come. Mind your harmonics and spurs, those things tend to be dirty so IMO I really wouldn't use such a thing. Another thought and another educated guess, if you lower the rig's output to 5W and use the amp likely it'll bring you back to the 100W the rig is capable of in the first place. <lulz>
"You could very easily be stuck with a brick."
How unkind but at least you tell it like it is, we call mobile amps (VHF in particular) bricks. <more lulz>
73 de Warren
Amateur Radio KB2VXA
Station powered by atomic energy, operator powered by natural gas.
Old 09-07-2009, 08:05 PM
kb0nly's Avatar
Sounds like another illegal CB amp, brought to you by the pit we know as FleaBay...
www.kb0nly.net
www.jeepkj.com
Similar Threads
Problem with UHF Mobile Amp conve36 Motorola Forum 13 04-17-2009 08:44 PM
4-way amp splitter trouble ocn29rsc Antennas and Coax Forum 9 09-22-2008 11:02 AM
Drop Amp & BC396T ROTTWEILERPM Antennas and Coax Forum 2 10-19-2007 11:09 PM
RH77CA and GRE Super Amp, bad combination?? kmacka Antennas and Coax Forum 13 05-25-2007 09:55 PM
Broadband drop amp HOLEBILLY Antennas and Coax Forum 3 01-16-2007 06:55 PM
