Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General Discussion Forum for Amateur / Ham Radio Topics
Old 09-07-2009, 09:40 PM
Question Kenwood TH-G71A Software Programming
Hello All,
Has anyone successfully programmed their h/t using the software? I've invested several hours trying to get the software to work, but it's been without success.
I bought the cable from EBAY. Downloaded the software from Kenwood. Typed in all the repeaters, pl tones, etc.
Went to "menu 15" turned it "on". It will not transfer the frequencies to the h/t. I keep getting "COM port is invalid. Please check and try again." I tried COM 2 and got the same error message.
There are only two Com ports available!!
Any ideas?
Alan
Old 09-08-2009, 08:59 AM
AYUDI's Avatar
What kind of cable USB or DB9. If it is a USB cable you need a driver for most of them.
Al
Old 09-09-2009, 12:09 PM
Question
Hi Al,
Yes, the wire is a USB and it did come with a "mini cd" for the driver. I did install the driver into the laptop, but it still will not upload the freq's into the h.t.
Alan
Old 09-09-2009, 12:22 PM
AYUDI's Avatar
I think you hit a software limitation that radio went out of production when USB was coming out. It is looking to use the serial ports. The software probably was not updated by KW to accept usb devices. Hopefully someone who knows more than I do can help.
Al
Old 09-13-2009, 08:38 PM
chief21's Avatar
Default Re: Kenwood TH-G71A Software Programming
I used to own a G71 but sold it, so I can't check this out myself...
Mnny Kenwood HT's use the earphone port for the PC connection as well, and there is a menu selection that has to be set in order to select the appropriate input. Is the G71 one of these perhaps? I don't remember.
chief21's Avatar
Many Kenwood HT's use the earphone port for the PC connection as well, and there is a menu selection that has to be set in order to select the appropriate input. Is the G71 one of these perhaps? I don't remember.
Old 09-13-2009, 09:07 PM
chief21's Avatar
Default RE: Kenwood TH-G71A Software Programming
One other point.... when installing USB-serial converter cables, windows will often select a com port other than 1 or 2. (mine uses comm 6).
Old 09-29-2009, 04:02 PM
under settings try "com 4" thats what i have to use to program my VX-800.
Similar Threads
KENWOOD TK 840 Programming help wanted bailenforcer Kenwood Forum 7 10-14-2009 10:30 PM
FS: Kenwood TK-260 and Programming laptop PACKAGE! and many Accessories chrismoll Old Classifieds Archives 4 07-18-2008 02:45 PM
FS: Commercial Radio Programming. /\/\ and kenwood ke5fgc Old Classifieds Archives 0 07-09-2008 09:26 PM
Programming software to control a scanner Gilligan Scanner Programming Software 5 01-19-2006 11:24 PM
