Heathkit 2036A Transceiver
hamradiook
oklahoma
HI Hope we might have someone that can troubleshoot this trans ceiver. Receive works fine. On the transmit side, key the mic and it KICKS out in one second. No movement of the SWR meter. Take of antenna and put dummy load on and works fine will say in transmit mode till you let of the MIC, and swr meter reads.
Cant seam to fine the problem????????
John
fineshot1
NJ USA (Republic of NJ)
John
A dummy load simulates a perfect antenna load which is typically 50 ohms.
What were you using as an antenna prior to hooking up the dummy load as
that sounds like it was your problem?
hamradiook
oklahoma
antenna
Im not doing the work one of the guys in our Ham club is, BUT he has the same radio that he bought ne in the day and his works fine with same antenna. I think its a home made J pole??
John
K4IHS
Charlotte, NC
I think he meant to type "take off" the antenna and put on a "dummy load" and all is well. Sounds like the antenna, antenna feed line or one of the connectors is the problem?
hamradiook
oklahoma
heath 2036A
OK my ham buddy that is actually doing the work is at churc rigtht now. Will forward all this. I think ,but will recheck with him that he has checked all that. Like i said before he has one of the 2036s that he bought new in the day. Its in his truck and he has been using it all these years. I think he has had mine in there and that didnt fix it. ill get back to everyone later in the day. have a great holiday week end.
John KN5UPS
k8tmk
Stevensville, MI
Having written the manual for the HW-2036A, I have three of them here in use all the time. Never a problem with any of them.
I agree that the external antenna must be the problem. A high VSWR is obviously causing the radio to "go out of lock."
Randy
gcgrotz
Savannah, GA
Try aligning the synthesizer. An out of lock condition will cause it to unkey. I have a vague memory of that happening to mine way back. I just sold that thing a couple years ago, still worked great, 9.5 watts.
hamradiook
oklahoma
heathkit 2036 wont stay locked on transmit
I just got a note today from Earl who is in our ham club here, and is doing the work.
He has been out of town and not worked on the radio. He did say he thinks he found it. Couple diodes bad in the synthesizer circuit. Close to the back of the board near the finals and the antenna jack. he will replace them tonight and well see if that does it.
John KN5UPS
SAR923
John, make sure you recheck that antenna before you transmit again. A high SWR can fry diodes in the final, so that may be the cause of your problem.
