I have a Tripp-Lite PR-25 power supply, 20 amps cont. 25 amps peak, and in it there is an AFE 5A 250V fuse. Now how does a 5 amp 250 volt fuse work in a 13.8 volt 25 amp power supply? I have never had an issue with the fuse it just seems odd to me.
I just want to make sure I have the proper fuse in line of the outlet which I guess would be a 25 amp fuse as my ps is rated at 25 amps max.
If I'm wrong let me know please.
If you're using a single fuse, then that might be appropriate. But it would provide no protection for devices that use less current. A better way would be to separately fuse each output, with a fuse properly sized to the specific load, on each specific output.
In other words, just trust the fuses that are already inline with my equipment?
So are you saying add a second fuse of the same type for each peice of equipment? A 30 amp fuse for my hf rig in addition to the in-line 30 amp fuse it already has.
There are quite a few 12VDC "power strips" available from ham radio dealers. Take your pick and don't make fusing redundant, it should be one or the other and not both. It seems to me that someone has used the wrong fuse for that radio, check the manual and replace it with the correct value. One other thing, eliminate the fuse in the negative battery lead, if it blows for some odd reason you'll go batty when weird problems show up and never figure out why it blew in the first place. Yeah, it happened to me and drove me nuts until I found the blown fuse.
Here's a thought, your power supply can only run one radio at a time and has little to no headroom for future expansion. I use a Tripp Lite PR-60 which although a bit pricey will run my entire station without breaking a sweat, 60 amps being a bit overkill but I love it. There is a big market for 20A regulated supplies, you'll have no trouble selling it.
On TX my HF rig draws 20 amps
