Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion - General discussion forum for amateur radio topics not covered by the above forums.
Old 04-12-2012, 2:41 PM
jaymatt1978's Avatar
Default 2 meter simplex frequencies
Even though I know there are others the three main 2m simplex frequencies are 146.5200, 146.5350 and 146.5500. I have these three frequencies grouped together and was wondering if people do the same thing with their radios??
Old 04-12-2012, 3:55 PM
The first one, 146.520, is the agreed upon national calling frequency. The others I've never heard of before. If they are common ones in your area then keep them. They aren't common here, so I don't bother putting them in memory.
- 'Doc
Old 04-12-2012, 5:05 PM
trsundstrom's Avatar
Mentor
Look at the ARRL site for the bandplan. 146.52/.55/.58 are pretty commonly used. In crowded areas like NY, Phila, there are those hams that go to the 15 kHz step, 146.535/.565/.595, but activity by comparison is minimal. I wouldn't bother programming the 15 kHz steps either. On 147, 147.42/.45/.48 are defined simplex frequencies but it's been my experience there is little activity on these as well. In the car I just keep the 52/.55/.58 simplex frequencies in memories so that we can switch from the "national calling frequency" of 146.52 or a repeater. Bandplans are also usually available on the local coordinators' web sites as well. For the neUSA I have a list here Amateur Radio : FM. Especially in the NYC/NNJ area there are a number of 2m 1 MHz-split repeaters, and some of the "national bandplan" simplex frequencies are adjacent to repeater inputs or outputs. HTH.
Tom - W2XQ - w2xq.com
Old 04-14-2012, 1:03 AM
Here in rural Iowa there is more simplex then repeater stuff. Some guys runs down in the 144's and other up in the 147's and most on the simplex band plan channels around 146.520. There is a D-Star repeater local to me running a -.99 offset. The input freq is on 146.415. There was actually a group of guys using that frequency on a daily basis.
Tim
Old 04-14-2012, 2:20 PM
newsphotog's Avatar
I keep 146.52, 146.55, and 146.58 programmed in all of my radios and keep them in my primary scan list. In addition to 146.52 being the primary calling channel, 146.55 is the secondary and is usually utilized by storm spotters/chasers for car-to-car when they're traveling in groups.
It's nice to have them all programmed them so I can scan them and so I don't have to spin the VFO to find a clear frequency.
Old 04-14-2012, 7:27 PM
kb2vxa's Avatar
Tom said it best since the 2M band plan varies from area to area, California uses an odd spacing (30KHz?) and in large metro areas some simplex frequencies are used for repeaters with a -1MHz split. Just one thing to add, to save channels I programmed the national calling frequencies and active repeaters on 6M, 2M, 1.25M and 70cM leaving the rest for the VFO, a quick slide is easier than poking around the memory. Then there are other modes besides FM, even more fun and strictly VFO outside the channelized band segments.
Old 12-11-2013, 3:18 AM
Default 2m simplex
In my FT-7900, I have ALL of the 2 meter simplex channels programmed in. True, I really only need just the two or three more popular ones, but my thought is if, for whatever reason, I want to go somewhere else, the rest of the simplex channels are already there without the need to “dial them in”.
Old 12-11-2013, 11:42 PM
sparks40's Avatar
ARCC - Main Page
MetroCor.net
UNYREPCO
The three links above are for repeater coordinators in and nearby the New Jersey area. They should give you an idea regarding FM simplex within their respective band plans.
Old 12-16-2013, 1:46 AM
jmp883's Avatar
I keep just the primary calling frequency, 146.520, programmed in my mobile, base, and HT radios. Living in northern NJ I've noticed that 146.520 seems to be active late at night. Many times while driving to work for the midnight shift (I leave at 11pm) there is a QSO going on. I have a 30+ mile each-way commute from Morris County to Passaic County and most of the QSO's I've heard on the NCF seem to come out of Bergen County, NJ or the various boroughs of NYC.
Amateur Callsign: KC2PJL
Emergency Services Dispatcher
Charter Member of The Red Knights International Motorcycle Club, NJ Chapter 15
Old 12-17-2013, 5:13 PM
kb5zcs's Avatar
Wirelessly posted (Mozilla/5.0 (iPhone; U; CPU iPhone OS 4_2_1 like Mac OS X; en-us) AppleWebKit/533.17.9 (KHTML, like Gecko) Version/5.0.2 Mobile/8C148 Safari/6533.18.5)
We use 146.520 simplex here in Brownsville Texas all the time sometime we get a pretty good round table a going.......
http://www.qrz.com/db/kg5euu
Brownsville Digital Group A.R.C.
WORKING THE WORLD WITH 5 WATTS AND A RUBBER DUCK.
Old 12-17-2013, 5:40 PM
jhooten's Avatar
147.555 was popular when I was still in the panhandle of Texas.
Jerry
I read it on the internet, so it must be true.
Old 12-18-2013, 6:24 PM
kg4ojj's Avatar
146.520 is used, in my area, for calling and general conversation.
146.550 is defined by several counties' ARES groups as their primary simplex
146.580 or any of the 15 kHz spaced ones are not routinely used in northern FL.
Like others, when mobile, I scan -520.
If you are a ham in GA, KY, MS, NC, SC, TN, VA, and WV, the SouthEastern Repeater Association (The SouthEastern Repeater Association, Inc. :: Home) publishes a PRINTED journal quarterly. In it, you will find all of the coordinated repeaters for those states. On top of that list is all of their recommended simplex frequencies for VHF and UHF. SERA does not put their database online. You'll have to find a repeater owner or PM me if you want to know what's on their list (and it isn't that much to see).
Jay Reid ~ KG4OJJ
Old 12-19-2013, 1:12 AM
profiledescent's Avatar
Originally Posted by kg4ojj View Post
…..146.580 or any of the 15 kHz spaced ones are not routinely used in northern FL.
Actually, you'll find 146.580 getting lots of use in many North and Northeast Florida counties. The ARES groups in Lake, Duval, St. Johns, and Flagler all publish it in thier plans, as well as a small rogue ECOMM group in Flagler. I hear quite a bit of traffic on it in St. Johns and Flagler.
Old 01-08-2014, 10:43 PM
According to the ARRL 2-Meter Band Plan, the 2-Meter simplex frequencies are:
146.400, 146.415, 146.430, 146.445, 146.460, 146.475, 146.490,
146.505, 146.520, 146.535, 146.550, 146.565, 146.580, 146.595,
147.420, 147.435, 147.450, 147.465, 147.480, 147.495, 147.510,
147.525, 147.540, 147.555, 147.570
The only "special one" is 146.520, the "national simplex calling frequency". In some areas, 146.400 is used as a repeater input.
I have them all programmed into my radio. Several of them get used regularly around here in the Indianapolis area.
Hope this helps.
Old 01-09-2014, 12:32 AM
Originally Posted by bill4long View Post
According to the ARRL 2-Meter Band Plan, the 2-Meter simplex frequencies are...
...Hope this helps.
I can't stress this enough:
FORGET THE ARRL BAND PLAN! (yes I was yelling).
Check with your local frequency coordinator, and other people who actually operate on 2m simplex to find out what's actually in use in your area. Someone coming along and looking at bill4long's list here in California could very well be stomping on someone's repeater input frequency, or some other specialized usage, and they would never even know it.
Examples:
146.400 is the input to the infamous 147.435 repeater.
146.430 is an intercom channel for amateur television and gets repeated over a wide area on television transmitters.
146.460 is a remote base to remote base intercom channel.
146.475 is a repeater input
147.490 is a repeater input
147.505 is a repeater input
Etc. etc. etc.
The ARRL bandplan is COMPLETELY USELESS (yes, I'm yelling again) in Southern California, and many other areas as well.
Please, please, please, find out who your local coordinating group is and get the list that THEY put out for your local area.
Your fellow hams will thank you.
@bill4long... I'm sorry, but I though it important to get the word out. ARRL bandplans are useless if a local bandplan overrides it. This is something that new hams in particular need to understand.
Science flies you to the moon. Religion flies you into buildings.
Old 01-09-2014, 12:45 AM
Mentor
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.1.2; en-us; DROID BIONIC Build/9.8.2O-72_VZW-22) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Bill4long, that might be the ARRL "national" plan but, as KB2VXA and I wrote above, the band plan of the local coordinating group probably is the best info source. If you dump in all those 15 kHz steps and expect to scan/use them in cNJ, it would be impossible. Between NYC and Phila repeaters and the 1 MHz splits, good grief.
I have to say in all the years working throughout NJ's 21 counties, driving to cVA, nVT, and 6+ years out to Indy and West Lafayette, 146.52/.55/.58 are mostly quiet.
I find the multi-site repeater wide area systems to be most active. I recall one in Indy covered a couple of states. Memory is rusty; is it 146.85?
HTH.
Old 01-09-2014, 5:48 AM
W9BU's Avatar
Lead Wiki Manager
Folks, this is kind of an old thread that has come back to life. Let's not make it tangential in the process. I've moved the NY/NJ/DC repeater question to a new thread.
http://forums.radioreference.com/ama...endations.html
Lead Wiki Manager and Forum Moderator.
"The whole world's living in a digital dream. It's not really there, it's all on the screen." -- WB6ACU
Old 01-09-2014, 5:55 AM
elsinga's Avatar
Tnx!
PC5E/Robert Elsinga =8- )
Icom IC7000, Polmar DB-50M and Uniden UBC3500XLT, filled to the limit.
Old 02-04-2014, 11:19 PM
jim9251's Avatar
.52 is pretty common here and busy during tourist season. I even have a "I monitor 146.520" sticker on the back of my Jeep. The other simplex channels are used at time by local ham clubs.
Uniden BCD996XT, Yaesu ft-1900r, Kenwood TS-870, Baofeng UV-5R ht, AnyTone AT778UV
Old 02-05-2014, 1:09 AM
elsinga's Avatar
Okay, I will monitor 146.52 then. 73!
