Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General discussion forum for amateur radio topics not covered by the above forums.
Old 12-17-2012, 8:17 AM
Default Echolink link radio keys down when Echolink is closed
When I close Echolink or my computer restarts, my echolink link radio will just stay keyed down. Is there a setting somewhere to prevent this?
Thanks,
Tim
Old 12-17-2012, 7:10 PM
trsundstrom's Avatar
Mentor
Wirelessly posted (Moto Droid Bionic: Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; DROID BIONIC Build/6.7.2-223_DBN_M4-23) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Err, Echolink doesn't use a radio??? What am I missing?
Tom - W2XQ - w2xq.com
RS PRO-2041 & PRO-106
Old 12-17-2012, 7:35 PM
n9mxq's Avatar
It does if it's in Link or Repeater mode. How are you keying the radio?
Gene
If you can't post something helpful, don't post.
Old 12-17-2012, 10:55 PM
I'm using a Rigblaster M8. My echolink setup is for repeater mode.
Tim
Old 12-17-2012, 11:01 PM
n9mxq's Avatar
And the Rigblaster uses serial port keying to accomplish transmit? I'm thinking something on the serial port is getting left high (or low) whether it's RTS or CTS when the software exits.. I'm not familiar with the Rigblaster so I'm only guessing.
Gene
Old 12-17-2012, 11:08 PM
Yes, the serial port is hooked to the rigblaster which in turns keys the radio.
Tim
Old 12-17-2012, 11:11 PM
n9mxq's Avatar
can you switch from RTS to CTS to key the radio (or visa versa)? It may be what you need. Check the manual for the Rigblaster.
Gene
Old 12-17-2012, 11:13 PM
I have tried both settings. Both will still key the radio up upon exiting the program.
Tim
Old 12-17-2012, 11:36 PM
n9mxq's Avatar
That would be the only thing I could think of, unless you're using a USB-Serial adapter instead of a hardware serial port.
Gene
Old 12-28-2012, 9:41 AM
Al42's Avatar
Two things come to mind:
1) When the computer reboots, the state of the serial port is undetermined, so you have to accept the key-down or disconnect the repeater or Rigblaster during boot.
2) It sounds as if the idle state of the lines is set to key down, and the program is set to keep them active for key up - which would have the Rigblaster key down when the program stops running. I've never used Echolink with a rig, but I suspect that you can reverse the keying sense in the software and in Rigblaster. A voltmeter would tell you what's going on here. Active is around -10v to -12v for an RS-232 pin. The pins should sit at a slightly positive voltage when the transmitter shouldn't be keyed. (Computers rarely meed RS-232 specs, which call for +12 idle and -12v active. But the Rigblaster should work with -10v active and a couple of volts positive for idle.)
