RadShackFan
I currently have a 50 watt, Kenwood TM-241 installed in my vehicle. The antenna, Lasen 5/8 wave, is roof-mounted with an NMO mount. I also have a Dell Laptop computer being powered by a power inverter. Been using this setup for about 2 years with no problems. (Cords/cables for all equipment do not mingle together.)
I needed to change the antenna to a 1/4 wave due to some clearance problems with the 5/8 wave. When I made the change this problem occurs: Keying the microphone on med or high power, the inverter powers off/on and the computer restarts. Changing back to the 5/8 wave solves the problem.
I put ferrite chokes on the power line feeding the inverter, the power line to the Dell, and the 2 USB cables plugged in to the computer. The antenna mount cable is low-loss & double-shielded RG-58. Have double checked all connections and SWR is perfect. Problem still exists when using the 1/4 wave.
Any ideas or solutions?
