Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General discussion forum for amateur radio topics not covered by the above forums.
Old 01-05-2013, 7:03 PM
Default FCC Narrow banding
Being a new tech, I was wondering if the FCC narrow banding implementation has any affect on the ham bands.
Old 01-05-2013, 10:32 PM
mdulrich's Avatar
No, other than old non-narrowband capable radio equipment becoming available in the second hand market.
Streaming the Allen County, Ohio Public Safety Scanner at http://www.broadcastify.com/listen/feed/188
Providing ADS-B data from NW Ohio for http://www.flightradar24.com
Old 01-06-2013, 8:25 AM
rapidcharger's Avatar
Location: Bringing you happy thoughts and crunching the numbers daily since 2012
Send a message via ICQ to rapidcharger
No and in addition to the reply above, newer commercial gear is going to be narrowband only. This means if you want to buy a commercial radio and use it on the ham bands, it's only going to do narrowband and chances are all the ham repeaters are wideband. Originally I thought this wouldn't become a problem for many years down the road, but they're already rolling off the line like this and some radios that currently do wideband analog (like the Motorola XPR 6550) will cease to do analog if you update to the latest firmware. I heard that Kenwood at least had the forethought to make an exception for the Ham Band so that those frequencies can be programmed wide.
Old 01-06-2013, 8:55 AM
Default Narrowbanding...
No, it only applies to Part 90 FCC licensees. As you already know, amateurs are governed by Part 97.
