KE7XD
I have some very bad noise in my shack. The worst is light dimmers in the house.. The shack is fed by four wires to a building about 140 feet away from the house. I put in a sub panel to feed the circuits. The panel box is grounded to the main box in the house, and the neutral is also tied to ground at the house. The new panel box also has ground rods at its site. For noise where should I put some bypass caps, from the legs to neutral or to ground? Should there also be a cap from neutral to ground? For lighting protection it sounds like everything should be grounded to a common point, but can I tie the ground and neutral together? I have read a lot of articles, however I have not come up with suggestions when using the four wires.
