Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General discussion forum for amateur radio topics not covered by the above forums.
Old 02-06-2013, 12:29 PM
KD2BMU's Avatar
Exclamation Distress call
I have a question regarding a General Class question.
G2B11
What frequency should be used to send a distress call?
Answer:
Whatever frequency has the best chance of communicating the distress message.
My question:
I am an EMT/ham operator with access to both at all times. How would I identify
myself? Using my ham call sign - KD2BMU or my call sign from my ambulance
service - Guilfoyle 473?
73
Dave
KD2BMU
Dave-KD2BMU
NYS EMT-B
Yaesu FT-2400H & VX-6R, Motorola CP200 & CP200XLS
Old 02-06-2013, 12:33 PM
Depends on what frequency. If on the 'company' frequency then using your company call sign. If on Amatuer radio then your amateur call sign.
Interoperatablity is not a technology it is an attitude!!!
Default Distress call
Coming from a public servant, this is what I would do.
If I on an amateur frequency, I would use my Callsign.
If I were on a public safety frequency, I would use my badge number or car/truck number. Example : if your car/truck number was 101. "101A to dispatch."
I hope this helps.
Andrew L.
KK4IFN
Sent from my iPhone using Tapatalk 2
Old 02-06-2013, 12:39 PM
KD2BMU's Avatar
It does. Thanks.
Dave-KD2BMU
NYS EMT-B
Old 02-06-2013, 3:23 PM
n5ims's Avatar
You should use whatever will cause the least amount of confusion to the other party. As was indicated above, if you're on a ham frequency, they expect a ham call sign so that should be used. On an EMS company frequency, they expect your EMS call sign so that should be used.
On 911, the ham call sign would confuse matters and slow down any response, as would your EMS call sign. That said, telling 911 that you're an EMT could be helpful (they generally understand that) and instead of going through the full script they may accept your evaluation of the situation if explained in terms that they normally would use with their EMS units.
Old 02-06-2013, 9:22 PM
KD2BMU's Avatar
Thanks for the info.
Dave-KD2BMU
NYS EMT-B
Old 02-06-2013, 10:41 PM
Use a cell phone like most people
Old 02-07-2013, 12:03 AM
robertmac's Avatar
Exclamation And if out of cell range
Not every place is covered by cells. Lots of times you may need your work radio or ham radio.
Old 02-10-2013, 7:03 PM
Default Needing Aid
If you have an emergency, you may use any frequency you desire to get help.
If it was my, it would be the most popular repeater I could get into.
If you need help, and you are transmit enabled on it, anyone is permitted to put a call out on any public service channel that would get you help, even if you are not a first responder ... in an emergency.
Old 02-10-2013, 7:09 PM
KD2BMU's Avatar
Thanks for all the great info everyone.
Dave-KD2BMU
NYS EMT-B
Old 02-10-2013, 8:00 PM
n5ims's Avatar
One thing to add to this, if you transmit where you're not licensed you should be prepared for whatever consequence may come from taking that action. If it's truely a life or death situation then any fine or jail time is probably worth it. If you're simply uncomfortable due to a fall and want help now instead of perhaps an hour or so when somebody most likely will pass by it probably isn't worth it.
Old 02-11-2013, 2:33 AM
JoeyC's Avatar
And keep in mind that 99% of what people would consider as an emergency do not qualify you to transmit on those freqs anyway.
Old 02-11-2013, 9:04 PM
From what I remember from my Tech class, we where told that in case of emergency, we are allows to use any frequency need to make contact, provided there are no other means of communication. In other words if there is a cell phone, or amateur frequencies available then we have to use that first. What constitutes an emergency? Only in a matter of life and death. If a person is dying, and nothing else is available, you are allowed to use any means of contact.
Old 02-11-2013, 10:59 PM
If there is an actual emergency, and if you make a call for help on some normally unauthorized frequency, then there are 'follow up' requirements you will have to do. Those requirements include reporting the fact to the proper authority (FCC) with all the reasons/facts of the incident. If it's a legitimate emergency I seriously doubt if there will be any penalty involved. I'm sure you'd probably get the typical , "Don't do that no more, unless you have to." sort of lecture, but that's honestly about it. Best make sure it's a legitimate emergency though.
- 'Doc
Old 02-12-2013, 5:30 AM
The test questions for a ham licence are oriented around Part 97 rules, so when you are asked about emergency frequencies the only correct answers are the ones that only include ham frequencies. The correct answer should probably read "Whatever amateur frequency has the best chance..."
I don't expect that the question writers are aware of the strange way RR members interpret the rules.
Radio Shack coax doesn't go bad. It's born bad.
Old 02-12-2013, 7:25 AM
Wirelessly posted (Mozilla/5.0 (iPad; CPU OS 6_0_1 like Mac OS X) AppleWebKit/536.26 (KHTML, like Gecko) Version/6.0 Mobile/10A523 Safari/8536.25)
Well put zz.
