Go Back   The RadioReference.com Forums > Amateur Radio > Amateur Radio General Discussion
Amateur Radio General Discussion General discussion forum for amateur radio topics not covered by the above forums.
Old 01-26-2014, 1:10 PM
Default Do you keep a station log? A radio log?
I'm new to radios, and waiting for my call sign after passing my technician exam last week. I wonder how many of you keep logs for your stations - do you record *everything* you do, or just contacts you've made... and do you keep separate logs for each radio, or just merge all your notes into one logbook?
I have a Yaesu FT-60r, planning to be involved in local disaster response efforts, but also looking forward to general listening and making contacts.
No doubt well off the topic...
Old 01-26-2014, 1:22 PM
You mean people still do that?
In the 2010s?
Old 01-26-2014, 1:33 PM
jand1958's Avatar
I do.
I keep one log and merge all radios into it. I just log actual QSO's. If somebody asks for a radio check, I probably won't log it. Even though it's not required any longer by the FCC, it's fun to go back and look at the contacts you have made.
I even kept a log back in the 70's for CB. Still have a few of those logs laying around after all this time.
Old 01-26-2014, 2:06 PM
k6cpo's Avatar
I keep a log for contacts made on HF, but that's about all.
i Keep a log using a database on my station computer. It makes it very easy
to sort and organize your contacts. If your involved with various awards such
as DXCC or WAS, or a million others, it is a huge aid in getting your QSO'S
sorted and organized..
I keep all basic info such as date/time/qth/mode/report and name. I do
not record rigs or shoe size..
Have close to 290,000 entries in my list which spans back to 1960. Lots of
fun looking back over the years to see some of the stations worked.
Old 01-26-2014, 2:29 PM
k3td's Avatar
I keep a log of my contacts on 160 - 2 meters for ssb/cw and the digital modes from home, but not for FM as I make too many of them and they are casual contacts - and are also primarily when operating mobile or portable.
I use the DXLab suite of integrated logging, propagation and spotting applications and have it interfaced to my IC-7700 radio so logging is just a couple of mouse clicks. The DXLab programs are freeware that are easy to install and use, and very well supported.
DXLab
Good luck and 73,
Tad, K3TD
EM10dq
Old 01-26-2014, 4:32 PM
Not only do I keep a log, but I record every QSO that I have made! It's really wonderful to be able to play back old conversations that you have had with old friends so many years ago.
Old 01-26-2014, 4:55 PM
Thanks, all. Yes, even in Twenty-Fourteen, I see the benefit of a logbook for various events related to contacts, equipment, etc.
Old 01-26-2014, 5:11 PM
elk2370bruce's Avatar
I have an access database that I created for all hf contacts. Various output reports can be easily assembled. Can also search callsigns for previous contacts. Nothing special - simple Microsoft Access application. Old habits die hard. As a Novice (many moons ago) I got in the habit of logging my activity and QSL status.
K C 2 P B J
Other useless license information.
List of my out-of-date radios.
Other data that nobody cares about.
Old 01-26-2014, 8:35 PM
Skypilot007's Avatar
I just keep a log of HF contacts in a simple Excel spread sheet. I don't bother with regular FM VHF/UHF repeater contacts. I suppose if I ever get into VHF/UHF SSB I would log those.
BTW, I would let the local officials handle the local disaster response efforts. Hams just get in the way usually. Helping with the walkathons and bikeathons is more what Hams can help out with.
Old 01-26-2014, 8:37 PM
Yes, I keep a paper log of all QSOs. In one of those ARRL log book at that. But then most (>95%) of my stuff is on HF.
I'm kind of retro that way. After doing computers at work all week, it's nice to just write something out on paper for a change.
Old 01-27-2014, 3:03 AM
When I started you had to keep a log of every transmission. That was relaxed quite a bit 'later', but I'd got into the habit. I think I have logs for HF stuff going back quite a few years (several moves in the mean time so don't bet on still having those logs). For VHF/UHF stuff I haven't kept a log at all, don't really see a need for it (make sense or not, what can I say?).
If I'm participating in some kind of 'regulated' net then I think it's a good idea to keep a log. If it's just casual conversation (normal BS'ing) then why bother? If you think it's worthwhile, then do it.
Most every log I've kept has been on paper. I've tried the computer logging, just too much trouble. And who says I wouldn't scramble the file anyway? Hey, I'm good at that!
A log is a record of a transmission. If you have a reason to make note of any particular conversation, for any reason at all, then do it.
- 'Doc
Old 01-27-2014, 9:06 AM
VE3JSO's Avatar
I log all my hf qso so I can upload it to lotw
- Jamie VE3JSO
Pro 90, Pro106, KENWOOD 450S, yeasu ft-60r, ft-2200
http://www.starrsoft.com/software/win500/
Old 01-27-2014, 9:18 AM
WB4CS's Avatar
I keep a log of all contacts I make on HF. On VHF/UHF I don't keep any kind of formal log, but I may jot down in a notebook the name and callsign of someone that I've not talked to before.
Brandon, WB4CS
Kenwood TM-V71A, TM-281A, TH-K20A. Yaesu FT-60R
Amateur radio is a hobby. We supplement emergency communications, not replace them.
Old 01-29-2014, 12:57 AM
vagrant's Avatar
Using a computer and HRD log, I note HF QSO's but not radio checks nor the regular rag chew with friends. I do log VHF/UHF satellite contacts as well, but never QSO's via a repeater. If I am portable, I will make paper logs, but I transfer them to the computer log once I am back home. From there it is pushed to several other online logs as a backup.
Transceivers, filters and antennas. Having fun in the sun.
Sharing ADS-B in California. (ka)
Old 01-29-2014, 7:15 AM
K7MEM's Avatar
Location: 1158 W. Valley Circle, Ash Fork, AZ 86320-482
I still keep a paper log, but have started recently to use the log capabilities of HRD. But in either one of them I am not specific about which rig I am using, other than differentiating QRP from QRO.
Although not very useful, I still have my logs from 1965, when I first got my license. At the time most of my operation was 2 Meter AM (Heathkit Twoer). I had the standard log entries, but I also use a 3x5 file box to log all of my contacts. Because all the contacts were local (within 50 miles), I talked to many of the same hams regularly. I used the file cards to record all of the names/dates/rig data and any unique information. They were always surprised at how good my memory was. I still have the file box and cards.
Old 01-31-2014, 9:42 AM
jmp883's Avatar
Like others here I keep a log of all my HF QSO's. The only VHF/UHF QSO's I log are when the bands are open or when I'm using Echolink.
I use both handwritten and computer-based logbooks.
Amateur Callsign: KC2PJL
Emergency Services Dispatcher
Charter Member of The Red Knights International Motorcycle Club, NJ Chapter 15
Old 01-31-2014, 10:15 AM
KD2BMU's Avatar
Default Re: Do you keep a station log? A radio log?
Could I get a copy of the Microsoft Access database you've create? I have tried to make different databases using it and can't seem to get the hang of it. I used a database for soldiers and enjoyed using it. It is much easier to filter different things.
Dave
KD2BMU
Dave-KD2BMU
NYS EMT-B
Yaesu FT-2400H & VX-6R, Motorola CP200 & CP200XLS
